Silver
Amount of buffers on ASR9001
I need to find out the amount of buffers on the ASR 9001 platform, both for integrated ports and
A9K-MPA-4X10GE.
Do anyone have these available?
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib CCIE #37149 Please rate helpful posts.
1 ACCEPTED SOLUTION
hi daniel,
the 9001 is based on the MOD80 linecard.
This linecard has 2 NPU's for the feature processing.
Each MPA bay has a dedicated NPU and also serves 2 of the 4 onboard 10GEs.
This NPU has several pieces of memory attached like a TCAM, stats memory, 2xsearch memory for each MAC and L3 FIB
and there is also buffer memory.
This buffer memory is shared is 1G in the TR version and 2G on the SE version of the linecard.
The "LC type" for the 9001 is the SE version hence you have 2G of buffer memory that can be used for all interfaces
depending on their qos policy-map configuration and more particular the queue-limit that is assigned to it.
you can use the command show qos int to see what the hw programmed for queue limit.
regards
xander
Xander Thuijs CCIE #6775
Principal Engineer
ASR9000, CRS, NCS6000 & IOS-XR
Xander Thuijs CCIE #6775 Principal Engineer ASR9000, CRS, NCS6000 & IOS-XR
hi daniel,
regards
xander
Principal Engineer
Silver
Thanks a lot Xander.
Daniel Dib
CCIE #37149
428
