03-25-2014 08:20 AM
Does anyone have any experience with getting command authorization to work on an ASR 9000 and using TACACS.NET?
If not, is there any way to just use TACACS for authentication and have all authenticated users thrown into the cisco-support level of authorization?
03-25-2014 10:23 AM
- Could you please let me know what version of code are you running.
You can perform the command authorization using the below CLI:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/security/command/reference/b_syssec_cr42asr9k/b_syssec_cr42asr9k_chapter_01.html#wp3674188447
Also let me know if you are looking for anything specific thing on ASR9k using tacacs.
Hope this helps.
03-25-2014 10:52 AM
I want to accomplish authentication through TACACS but authorization locally for all TACACS authenticated users without having to create users on the ASR. What would the recommended config look like for this?
I'm running 4.1.1
