ASR 9001 nV Connection
to use the nV feature with 2xASR9001, I will require 2 IRL of 10 Gbps.
I will be using the A9k-MPA-4x10GE (module to add 4x10GE ports). I would like to know if I would be able to use the ports of the module A9k-MPA-4x10GE to create the IRL? (They use XFP).
Thanks a lot.
J
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Jordi, Yes, you can use
Hi Jordi,
Yes, you can use either the MPA ports or on-board ports for IRLs, or even both. The restrictions on optics is that of the LC/MPA you are using.
EOBC ports are the only ones with more restrictions.
See section 3.6 and addendum of https://supportforums.cisco.com/docs/DOC-34114 for more details on the EOBC and 9001 limitations.
Sam
Hi Jordi,
Sam
Hi Sam,thanks a lot for the
Hi Sam,
thanks a lot for the document. that's what I was looking for.
Thanks.
J
84
