ASR 9k BNG - Selective Domain Stripping
hi friends,
I have a particular requirement in which i am recieving PPPoE Subscribers on ASR 9010 running 4.2.  I am recieving Subscribers Sessions in three formants
1)  username@abc.com
2) username@xyx.com
3) username1
Is it possible that  i let  username@abc.com go through radius authentication as it is, however for users with username@xyz.com , their domain should be stripped and only username is sent to the radius??
can some one share a template of configuration?? i saw in documentation that there a way to define aaa attribute format, but i couldn't understand how to apply it to the users?
Also what will be the Impact if i enable VPDN for L2TP LAC on the same router?
anyone please?
1 ACCEPTED SOLUTION
yup that can be done, here an example
!!!Define how the username is to be stripped in a format directive, one saves the domain, the other one the username.
aaa attribute format domain_strip
username-strip suffix-delimiter @
aaa attribute format domain_strip-2
username-strip prefix-delimiter @
!!!Define in a class map the domain to trigger on, in this case domain abc.com that is using the strip directive defined earlier
class-map type control subscriber match-any DOMAIN_ABC
match domain abc.com format domain_strip
end-class-map
!define a class for all the other users
class-map type control subscriber match-any EVERYONE
match protocol ppp
Next in the control policy leverage this newly defined class for username abc.com's:
policy-map type control subscriber CPMAP
event session-activate
class DOMAIN_ABC
10 authenticate aaa list default
class EVERYONE
10 authorize aaa list default format domain_strip-2 password use-from-line
now domain_abc will send its original username out, all the other ones will have their username stripped omitting the domain and send their password received from chap.
regards
xander
Xander Thuijs CCIE #6775
Principal Engineer
ASR9000, CRS, NCS6000 & IOS-XR
Xander Thuijs CCIE #6775 Principal Engineer ASR9000, CRS, NCS6000 & IOS-XR
1 REPLY
end-class-map
match protocol ppp
class DOMAIN_ABC
class EVERYONE
regards
xander
Principal Engineer
261
