02-21-2012 07:40 AM
Hello all,
Which are the ASR9000 MVPN Finite Resources ?
Number of mVPN Routes
Number of mVPNs
Number of MDTs
And which max values for each parameter ? Are them differente among XR versions ?
Thank you!
Solved! Go to Solution.
02-21-2012 07:54 AM
Hi David,
these are currently supported values:
mVPNv4 Routes 16k
mVPNs 200
MDTs 200
for the moment they are the same across the versions.
Alex.
02-21-2012 07:54 AM
Hi David,
mVPNv4 Routes 16k
mVPNs 200
MDTs 200
Alex.
02-21-2012 07:56 AM
Thanks Alexei!
02-21-2012 07:59 AM
I forgot one thing,
The MDT (default and data) entries will reside on the Global Mroute table. Which are the finite values for it ?
02-21-2012 12:53 PM
Hi David,
it is 16k Multicast Routes per system.
/A
02-21-2012 01:13 PM
Thanks (again) Alexei. We can assume that the 200 MDTs are Default MDTs right ? Or does it englobes the Data MDTs too ?
02-21-2012 11:45 PM
200 is the total amount of tunnels: default + data.
/A
02-21-2012 11:53 PM
If 1 Customer Group = 1 Data MDT, that's not much ..
Onde again many thanks Akiritich ! This forum is an amazing tool !
02-22-2012 06:33 AM
Fresh numbers for 4.2.0
02-24-2014 03:49 AM
Hi Alexei,
do you have the currently supported values for 4.2.3?
Thanks!
