ASR9006 BGP Policy Memory Error
Im working on asr9006 running RSP440 and XR 4.3.4, and after configuring and committing bgp neighbour and route-policy comnfig, the box complained with the errors below right after I committed the changes.
The changes were accepted and the box is idle, ie no traffic, and no prefixes as the bgp sessions are shut so the box is not busy
However it complains of a failed policy-in and being in an inconsistent state together with a memory allocation failure
The below is what I got on the console as soon as i committed the changes to my bgp process to define my bgp neighbour ip addresses and route policies
The last item in the log, the failed to allocate memory continues every minute, i believe its trying to regain some memory by resetting but not managing and going into a loop.
Have a case open with TAC but not joy so far.
anyone seen something like this before
thanks
Mark
RP/0/RSP0/CPU0:Apr  8 03:11:10.775 CET: config[65850]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'admin'. Use 'show configuration commit changes 1000000228' to view the changes.
RP/0/RSP0/CPU0:south05-ASR9006-TEL(config-bgp-nbr-af)#RP/0/RSP0/CPU0:Apr  8 03:11:10.868 CET: bpm[1060]: %ROUTING-BGP-5-ASYNC_IPC_STATUS : bpm-default:(A)inst-id 0, Connection Open
RP/0/RSP1/CPU0:Apr  8 03:11:10.938 CET: bgp[1045]: %ROUTING-BGP-5-ASYNC_IPC_STATUS : default, process instance 1:(S)inst-id 0, Connection Establised
RP/0/RSP0/CPU0:Apr  8 03:11:11.071 CET: bgp[1045]: %ROUTING-BGP-5-ASYNC_IPC_STATUS : default, process instance 1:(A)inst-id 0, Connection Establised
RP/0/RSP1/CPU0:Apr  8 03:11:12.467 CET: bgp[1045]: %ROUTING-BGP-3-CONFIG_SET : Notify for default/0/12709/ord_a/default/nbr/0x0/edm/ord_u/0x3/3e732d31/________/ord_s/0x0/ord_g/policy-in failed with error: 'ora_shared' detected the 'warning' condition 'PCL engine failed to pass in built parameters', system may now be in an inconsistent state.
RP/0/RSP1/CPU0:Apr  8 03:11:12.502 CET: bgp[1045]: %ROUTING-BGP-3-CONFIG_SET : Notify for default/0/12709/ord_a/default/nbr/0x0/edm/ord_u/0x3/2001200030800a9b0000000000000001/________/ord_s/0x5/ord_g/policy-in failed with error: 'ora_shared' detected the 'warning' condition 'PCL engine failed to pass in built parameters', system may now be in an inconsistent state.
RP/0/RSP0/CPU0:Apr  8 03:11:12.510 CET: bgp[1045]: %ROUTING-BGP-3-CONFIG_SET : Notify for default/0/12709/ord_a/default/nbr/0x0/edm/ord_u/0x3/3e732d31/________/ord_s/0x0/ord_g/policy-in failed with error: 'ora_shared' detected the 'warning' condition 'PCL engine failed to pass in built parameters', system may now be in an inconsistent state.
RP/0/RSP0/CPU0:Apr  8 03:11:12.553 CET: bgp[1045]: %ROUTING-BGP-3-CONFIG_SET : Notify for default/0/12709/ord_a/default/nbr/0x0/edm/ord_u/0x3/2001200030800a9b0000000000000001/________/ord_s/0x5/ord_g/policy-in failed with error: 'ora_shared' detected the 'warning' condition 'PCL engine failed to pass in built parameters', system may now be in an inconsistent state.
RP/0/RSP1/CPU0:Apr  8 03:11:12.740 CET: bgp[1045]: %ROUTING-BGP-5-ASYNC_IPC_STATUS : default:(S)inst-id 0, Initial Config Done
RP/0/RSP0/CPU0:Apr  8 03:11:12.871 CET: bgp[1045]: %ROUTING-BGP-5-ASYNC_IPC_STATUS : default:(A)inst-id 0, Initial Config Done
RP/0/RSP0/CPU0:Apr  8 03:11:14.900 CET: bgp[1045]: %ROUTING-BGP-3-NOMEM_RESET : [16] : Failed to allocate memory for update grp, resetting neighbor  : pkg/bin/bgp : (PID=2937152) :  -Traceback= 4225c65 421b4b7 822605f 82242b2 cda2c48 421d5b0 828e020
RP/0/RSP0/CPU0:Apr  8 03:11:20.430 CET: rmf_svr[377]: %HA-REDCON-1-STANDBY_READY : standby card is ready
RP/0/RSP0/CPU0:south05-ASR9006-TEL(config-bgp-nbr-af)#RP/0/RSP0/CPU0:Apr  8 03:12:15.463 CET: bgp[1045]: %ROUTING-BGP-3-NOMEM_RESET : [16] : Failed to allocate memory for update grp, resetting neighbor  : pkg/bin/bgp : (PID=2937152) :  -Traceback= 4225c65 421b4b7 822605f 82242b2 cda2c48 421d5b0 828e020
Hi Mark,I took a quick glance
Hi Mark,
I took a quick glance at the TAC case and it looks like the engineer got back to you today with further information on the issue. For all XR issues make sure you open the case under the XR OS technolgoy in order to get an XR/SP TAC engineer.
Sam
I've this problem too and it
I've this problem too and it has been solved adding a prefix over a empty prefix-set that we've created for block some prefix faster, look the config below as an example.
The problem...
#show rpl route-policy pfx_Peering-A detail
prefix-set DENY_EBGP_OUT
end-set
route-policy ADV_TO_Peering-A
if destination in DENY_EBGP_OUT then
drop
elseif (MY-POLICIES......)
The Solution...
1.1.1.1/32 --> I just add any prefix here, because the BUG CSCul39702 is hitting.
end-set
drop
423
