05-17-2018 06:14 AM - edited 03-01-2019 03:24 PM
Hello everyone.
Our customer plan to upgrade power supply on ASR9010 from
1) v1 DC (A9K-2KW-DC, VID: V01) to v3 DC (A9K-DC-PEM-V3 + PWR-4.4KW-DC-V3)
2) v1 DC (A9K-2KW-DC, VID: V01) to v3 AC (A9K-AC-PEM-V3 + PWR-6KW-AC-V3)
I can’t clearly understand replacing procedure.
For 1) in cli
#run
# pwrmod_change
In step 3 I don’t see “DC power supply version 3, fits …”For 2) In step 3 I don’t see “AC power supply version 3, fits …”How correctly replace power supply?
Solved! Go to Solution.
05-18-2018 07:29 PM
Good Day,
Thanks for checking. It seems the output in the doc is truncated. You will see following on the router itself:
1) AC power supply version 1, fits 3 across in single power shelf
2) DC power supply version 1, fits 3 across in single power shelf
3) AC power supply version 2, fits 4 across in single power shelf
4) DC power supply version 2, fits 4 across in single power shelf
5) AC power supply version 3, fits 3 across in single power shelf
6) DC power supply version 3, fits 4 across in single power shelf
I created DDTS CSCvj56819 to fix the doc.
Niko
05-18-2018 07:29 PM
Good Day,
Niko
