12-15-2009 08:05 AM
Is it possible, and how, to attach multiple ACs to L3 interface on IOS-XR ASR900.
Something like this configuration on ES20
interface Gi1/1
service instance 10 ethernet
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
bridge-domain 40
interface Gi1/2
encapsulation dot1q 20 second-dot1q 30
rewrite ingress tag pop 2 symmetric
bridge-domain 40
interface Vlan 40
ip address 1.1.1.1 255.255.255.0
Solved! Go to Solution.
07-21-2011 12:12 PM
Yes you can!
Taken an XR version > 4.0.1
and configure something like the following
int g0/0/0/0.1 l2trans
ecap dot1q 10
int g0/0/0/0.2 l2trans
ecap dot1q 20
l2vpn
bridge-domain X
bridge-group X
int g0/0/0/0.1
int g0/0/0/0.2
routed interface BVI 100
int bvi 100
ipv4 add......
Note that the BVI is untagged, meaning you need to pop all the tags in your BD for your EFP's in order to have the EFP talking to the BVI.
I have more info on that topic on my technote here:
https://supportforums.cisco.com/docs/DOC-15556
xander
sr Tech Lead ASR9000
CCIE
07-21-2011 12:12 PM
Yes you can!
ecap dot1q 10
ecap dot1q 20
l2vpn
bridge-domain X
bridge-group X
int g0/0/0/0.1
int g0/0/0/0.2
int bvi 100
ipv4 add......
xander
CCIE
