BGP Next-hop conflict with MPLS Label.
maritpra
Hi, Experts
Equipment: Cisco ASR9922, IOS-XR 4.3.2
Issue: I have problem that my RR do the next-hop-self by using route-policy for client routers, the next-hop is changed as intended but the MPLS label doesn’t changed to reflect the new next-hop.
What I would like to achieve: I would like RR to set next-hop-self only for selected prefixes(172.168.0.0/24, 0.0.0.0/0) but maintain original next-hop for the rest, I do this by using route-policy.
Detail:
I have routers running MPLS infrastructure with ASR9922 as an RR. RN router is in neighbor-group RN and CPE-xx routers are in neighbor-group AN.
  • •-       Every routers are in same BGP AS64549.
  • •-       RN sends prefixes 0.0.0.0/0 and 172.168.0.0/24 to RR.
  • •-       CPE-25 sends prefix 192.168.25.1/32 to RR.
Neighbor-group AN has the route-policy AN-OUT2 to set next-hop of prefix 172.168.0.0/24 and 0.0.0.0/0 to RR#loopback1 before send out update to CPE routers. Below is BGP and RPL configuration at RR.
router bgp 64549
nsr
bgp graceful-restart
ibgp policy out enforce-modifications
address-family vpnv4 unicast
  additional-paths receive
  additional-paths send
  additional-paths selection route-policy ADD-PATH-iBGP
  retain route-target all
neighbor-group AN
  remote-as 64549
  cluster-id 172.16.1.11
  update-source Loopback1
   route-reflector-client
   route-policy AN-OUT2 out
   soft-reconfiguration inbound
  if destination in DEFAULT or destination in RNC then
    set next-hop 192.168.10.11
  else
    pass
  endif
end-policy
This is what RR advertises to CPE-24
RP/0/RP0/CPU0:RR#show bgp vpnv4 unicast neighbors 192.168.10.24 advertised-routes
Fri Dec 20 15:23:14.931 BKK
Network            Next Hop        From            AS Path
Route Distinguisher: 64549:3339
0.0.0.0/0          192.168.10.11   172.16.1.1      ?
                                   172.16.1.2      ?
172.168.0.0/24     192.168.10.11   172.16.1.1      ?
                                   172.16.1.2      ?
192.168.0.1/32     192.168.10.11   192.168.10.24   i
192.168.0.26/32    192.168.10.26   192.168.10.26   i
192.168.25.1/32    192.168.10.25   192.168.10.25   i
192.168.211.8/30   192.168.10.22   192.168.10.22   i
The IP part works as intended but MPLS Label doesn’t work as intended. Please take a look at RN who is originates 172.168.0.0/24, label 16025 is locally assigned.
RP/0/RP0/CPU0:RN1#show bgp vpnv4 unicast labels
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop        Rcvd Label      Local Label
Route Distinguisher: 64549:3339 (default for vrf VLAN3339)
*> 0.0.0.0/0          0.0.0.0         nolabel         16025
* i                   172.16.1.11     16068           16025
* i                   172.16.1.13     16033           16025
*> 172.168.0.0/24     0.0.0.0         nolabel         16025
* i                   172.16.1.11     16059           16025
* i                   172.16.1.13     16024           16025
172.168.0.0/24 at RR, label 16059 is locally assigned, label 16025 is receive from RN router. It should send 172.168.0.0/24 with label 16059 to CPE-24 to reflect next-hop changed.
RP/0/RSP0/CPU0:RR#show bgp vpnv4 unicast labels
*>i0.0.0.0/0          172.16.1.1      16025           16068
* i                   172.16.1.2      16007           16068
*>i172.168.0.0/24     172.16.1.1      16025           16059
* i                   172.16.1.2      16007           16059
*>i192.168.0.1/32     192.168.10.24   131070          16060
*>i192.168.25.1/32    192.168.10.25   131070          16062
*>i192.168.211.8/30   192.168.10.22   131070          16065
What I found at CPE-24 which is Alcatel router is that, RR send prefix 172.168.0.0/24, nh 192.168.10.11 with label 16025 which is incorrect.
A:CPE-24# show router bgp routes vpn-ipv4 172.168.0.0/24
BGP Router ID:192.168.10.24    AS:64549       Local AS:64549
Legend -
Status codes  : u - used, s - suppressed, h - history, d - decayed, * - valid
Origin codes  : i - IGP, e - EGP, ? - incomplete, > - best, b - backup
BGP VPN-IPv4 Routes
Flag  Network                                            LocalPref   MED
      Nexthop                                            Path-Id     VPNLabel
      As-Path
u*>?  64549:3339:172.168.0.0/24                          100         0
      192.168.10.11                                      None        16025
      No As-Path
Routes : 1
On RR If I just remove the policy and do the next-hop-self under vpv4 address family, CPE-24 will get corrent nh with correct label(16059) but that won’t achieve our requirement to change nh only on selected prefixes. Is this software problem? Or is there any solution to work around?
Regard,
Marit
2 Accepted Solutions
Hello Marit,
I am able to recreate this in the lab, and unfortunately this scenario is not supported. BGP does not advertise allocated label if we set nexhop using route policy. The only way is by next-hop-self configured on RR, and yes it eventually will applies to all prefixes advertised to neighbor-group AN. Currently i do not have workaround available.
Below is the capture of what i have tested in the lab:
The topology:
CRS-4-02 ---------- CRS-8-01 ------------ ASR-9006-1
CRS-8-01 is Route-reflector of CRS-4-02 and ASR-9006-1.
CRS-4-02 advertise some prefixes.
This issue occurs when RR have route-policy toward ASR-9006-1, where it assign incorrect label. But it assign correct label if CRS-8-01 use next-hop-self.
Below is the test done in the lab if RR use next-hop-self:
RP/0/RP0/CPU0:CRS-4-02#show run router bgp
Tue Jan  7 08:16:18.945 UTC
router bgp 1
bgp router-id 172.16.4.1
address-family ipv4 unicast
neighbor 172.16.8.3
  remote-as 1
  update-source Loopback0
   route-policy PASS in
   route-policy PASS out
vrf RTAMAELA
  rd 100:1
   redistribute connected
RP/0/RP0/CPU0:CRS-4-02#show bgp vpnv4 unicast advertised  summary
Tue Jan  7 08:16:29.001 UTC
Network            Next Hop        From             Advertised to
Route Distinguisher: 100:1
78.22.11.2/32      172.16.4.1      Local            172.16.8.3
78.22.11.3/32      172.16.4.1      Local            172.16.8.3
93.22.15.61/32     172.16.4.1      Local            172.16.8.3
RP/0/RP0/CPU0:CRS-4-02#show bgp vpnv4 unicast labels
Tue Jan  7 08:16:53.655 UTC
BGP router identifier 172.16.4.1, local AS number 1
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0x0
BGP main routing table version 57
BGP scan interval 60 secs
Route Distinguisher: 100:1 (default for vrf RTAMAELA)
*>i22.51.32.77/32     172.16.8.3      16056           nolabel
*> 78.22.11.2/32      0.0.0.0         nolabel         16003
*> 78.22.11.3/32      0.0.0.0         nolabel         16003
*> 93.22.15.61/32     0.0.0.0         nolabel         16003
Processed 4 prefixes, 4 paths
RP/0/RP1/CPU0:CRS-8-01#show run router bgp
Wed Jan  8 11:07:05.436 UTC
router bgp 1
  allocate-label all
neighbor-group AN
  remote-as 1
   next-hop-self                              <-- use next-hop-self toward ASR-9006-1
neighbor-group RN
  remote-as 1
  graceful-restart
   next-hop-self
neighbor 10.10.10.10
  remote-as 1
neighbor 72.15.48.5
  use neighbor-group AN
neighbor 172.16.4.1
  use neighbor-group RN
RP/0/RP1/CPU0:CRS-8-01#show bgp vpnv4 unicast labels
Wed Jan  8 11:07:09.091 UTC
BGP router identifier 172.16.8.3, local AS number 1
Table ID: 0x0   RD version: 344169
BGP main routing table version 92
*>i22.51.32.77/32     72.15.48.5      16000           16056
*>i78.22.11.2/32      172.16.4.1      16003           16053
*>i78.22.11.3/32      172.16.4.1      16003           16054
*>i93.22.15.61/32     172.16.4.1     16003           16055
RP/0/RSP1/CPU0:ASR-9006-01#show run router bgp
Wed Jan  8 17:02:02.796 UTC
router bgp 1
bgp router-id 72.15.48.5
neighbor-group RR
  remote-as 1
  graceful-restart
neighbor 172.16.8.3
  use neighbor-group RR
neighbor 192.169.1.2
  remote-as 1
vrf RTAMAELA
  rd 100:1
RP/0/RSP1/CPU0:ASR-9006-01#show bgp vpnv4 unicast labels
Wed Jan  8 17:02:04.381 UTC
BGP router identifier 72.15.48.5, local AS number 1
Table ID: 0x0   RD version: 253825
BGP main routing table version 126
*> 22.51.32.77/32     0.0.0.0         nolabel         16000
*>i78.22.11.2/32      172.16.8.3      16053           nolabel          <== 172.16.8.3 is the loopback address of CRS-8-01
*>i78.22.11.3/32      172.16.8.3      16054           nolabel
*>i93.22.15.61/32     172.16.8.3      16055           nolabel
From output above we can see that ASR-9006-01 received correct label for each prefix.
Below is the output with route-policy configured and ASR-9006-01 receive incorrect label:
Wed Jan  8 11:04:46.310 UTC
router bgp 1
  allocate-label all
neighbor-group AN
  remote-as 1
   route-policy RTAMAELA out
neighbor-group RN
  remote-as 1
  graceful-restart
   next-hop-self
neighbor 72.15.48.5
neighbor 172.16.4.1
RP/0/RP1/CPU0:CRS-8-01#show run route-policy RTAMAELA
Wed Jan  8 11:16:06.847 UTC
  if destination in RNC then
    set next-hop 172.16.8.3
  else
    pass
  endif
end-policy
RP/0/RP1/CPU0:CRS-8-01#show run prefix-set RNC
Wed Jan  8 11:16:12.099 UTC
prefix-set RNC
  78.22.11.3/32
end-set
Wed Jan  8 11:04:33.512 UTC
Table ID: 0x0   RD version: 344013
Wed Jan  8 16:59:41.601 UTC
router bgp 1
neighbor-group RR
  remote-as 1
  graceful-restart
neighbor 172.16.8.3
  remote-as 1
vrf RTAMAELA
  rd 100:1
RP/0/RSP1/CPU0:ASR-9006-01#show bgp ipv4 unicast labels
Wed Jan  8 16:59:52.173 UTC
Wed Jan  8 17:00:00.457 UTC
Table ID: 0x0   RD version: 253701
BGP main routing table version 123
*>i78.22.11.2/32      172.16.4.1      16003           nolabel
*>i78.22.11.3/32      172.16.8.3      16003           nolabel   <-- It receive label 16003, which is wrong. it should receive label 16054.
*>i93.22.15.61/32     172.16.4.1      16003           nolabel
Rivalino
The MP-BGP vpnv4 unicast AF is to advertised the VRF prefixes. But eventually it is the IGP that will route the packet to destination.
For vrf-RN <--> vrf-AN:
With the logical topology, the AN will advertise its VRF prefixes to RN with AN's loopback as nexthop. And then the IGP will take the packet from RN to AN's loopback and vice versa. Looking at the physical topology, we can say that the packet should transit via RR, as this is the only way to reach AN from RN.
for vrf-AN <--> vrf-AN:
Each AN will advertise its loopback as the nexthop for each VRF prefixes. And RR will reflect this route advertisement to other AN router without changing the next hop address. This means that AN1 will receive VRF prefixes from AN2 with AN2's loopback as its nexthop. After this the IGP will be responsible to carry the packet from AN1 to AN2, and IGP will take shortest path. If you run ISIS between AN1 and AN2 on its directly connected link, then the packet will not go through RR, but it takes shortest path which is directly connected link.
rivalino
5 Replies 5
Rivalino Tamaela
Hello Marit,
As you have opened TAC case, I will follow up on that case.
thanks,
Rivalino
Hi Rivalino,
I just see your message here.
Thanks.
Hello Marit,
The topology:
router bgp 1
neighbor 172.16.8.3
  remote-as 1
vrf RTAMAELA
  rd 100:1
Table ID: 0x0
router bgp 1
  allocate-label all
neighbor-group AN
  remote-as 1
neighbor-group RN
  remote-as 1
  graceful-restart
   next-hop-self
  remote-as 1
neighbor 72.15.48.5
neighbor 172.16.4.1
router bgp 1
neighbor-group RR
  remote-as 1
  graceful-restart
neighbor 172.16.8.3
  remote-as 1
vrf RTAMAELA
  rd 100:1
router bgp 1
  allocate-label all
neighbor-group AN
  remote-as 1
neighbor-group RN
  remote-as 1
  graceful-restart
   next-hop-self
neighbor 72.15.48.5
neighbor 172.16.4.1
  else
    pass
  endif
end-policy
prefix-set RNC
  78.22.11.3/32
end-set
router bgp 1
neighbor-group RR
  remote-as 1
  graceful-restart
neighbor 172.16.8.3
  remote-as 1
vrf RTAMAELA
  rd 100:1
Rivalino
Hi Rivalino,
That's answer the issue i'm faceing, anyway i'm looking into the work around..
If we go back one step further, the reason I do this is
AN-AN communication: I would like it to take shortest path in golbal-routing instead going back and forth between         AN-RR-AN. This is actually X2 interface for mobile node while AN is actually access node that eNodeB connected to.
AN-RN communication through RR: PN is inline-RR where there is MPLS-TE configure in network like this.
[AN]---mpls-te---[RR]---mpls-te---[RN]
[AN]---isis_b-----[RR]---isis_a-----[RN]
I would like to drive traffic from AN-to-RN trough tunnel-te that why i need to set next-hop-self. This is actually S1 traffic and RN is a router that EPC connected to.
Work Around:
Is there anyway to drive traffic from AN to RN through tunnel-te without sacrifying AN-AN communication? UMMT3.0 say that AN should do BGP with pre-aggregate node(RR) in the same ring where next-hop-self won't hurt cuz it is in same ring. In my case AN do BGP with aggregate node NOT in the same ring and it is far away.
rivalino
