Cisc ASR9K licensing
Hi guys,
Can someone please point me out a licensing guide, something that clear explain what each license activates in terms of features, I have looked at the Feature navigator and there is no option for IOS-XR, I'm trying to build a config for two 9001 and I'm lost on the licensing
Ex in FN for IOS: for BGPv4 you need Adv-IPServices
Kind regards,
Bruno
Everyone's tags (5)
Bruno,
Please check out the licensing white paper.
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/ASR9000_SWE_User_whitepaper.pdf
Bryan
Hi Bruno,
You can check the licensing concepts on the software entitlement guide for ASR9K here:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/system_management/configuration/guide/b_sysman_cg43asr9k_chapter_0110.html
and here:
After this, you can check description of licenses applicable to the LC you are using on the LC datasheet.
For MOD80 or MOD160, for example, the information is found on table 5 here:
http://www.cisco.com/en/US/prod/collateral/routers/ps9853/data_sheet_c78-663866.html
Best regards, Gustavo
OK Guys,
From what I could understand for the following config:
1x ASR9001
1x A9K-MPA-20x1GE
I should consider the following:
----- From the first link "Core routing features are available for use without any license." -- IGP, BGP, IPv4 and IPv6, multicast routing ... are there as a standard feature
----- I assume that features such has QOS, EEM, IP SLA ....  are there also by default without the need of an extra license
----- So if I need up to 8 VRF's per slot I will need "A9K-iVRF-LIC"   or  "A9K-9001-AIP-LIC" for full scale VRF
Am I correct ???
Thank's in advance,
Bruno
You are correct w.r.t. the statements below:
W.r.t:
Yes, but I would like to tell you that ASR9001 has an embedded -SE Enhanced LC, 4 on-board 10GE ports and two MPA slots. So, A9K-IVRF-LIC is applicable to the whole chassis (8 VRFs per system, and not per MPA slot).
Hi Andre,
Just another quick question, while building the config on Netform-X I see 4 aditional options regarding  "application"  !!!!!
A9K-CORE
A9K-DATACENTER
A9K-MOBILE
A9K-OTHER
All of this have a price list of zero....Do you know what are this options related to ?
Kind regards,
Bruno
Hi Bruno,
For tracking purposes.
Hi Andre,
I know that 9001 is the "small" 2RU and I had the doubt regarding the fixed 4x10Gbps interfaces in terms of licensing, so it's safe to consider both MPA's (2) and the fixed 4x1Gbps has one slot only .... and you have just aswered that   THANKS
Best regards,
Bruno
1994
