08-20-2013 11:16 AM
Hi actually we have the follow topology network:
We try to merge both MPLS with inter -AS we have table on BGP for vrf prueba and announce and advertise the loopback 400 but is unreacheble for ping the network
Configuration on cisco ASR-1:
vrf prueba
address-family ipv4 unicast
import route-policy pass-all
import route-target
64512:2005
export route-policy pass-all
export route-target
64512:2005
interface Loopback400
vrf prueba
ipv4 address 172.16.162.12 255.255.255.255
interface GigabitEthernet0/2/0/17
cdp
mtu 1550
ipv4 address 172.16.19.130 255.255.255.252
router bgp 64512
bgp router-id 172.16.161.1
address-family vpnv4 unicast
neighbor 172.16.19.129
remote-as 2005
route-policy pass-all in
route-policy pass-all out
vrf prueba
rd 64512:2005
redistribute connected
redistribute static
mpls ldp
router-id 172.16.14.1
interface Bundle-Ether100
discovery transport-address interface
RP/0/RSP1/CPU0:ED_MEX_1#sho route vrf prueba
Tue Aug 20 13:05:54.483 UTC
Codes: C - connected, S - static, R - RIP, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR
A - access/subscriber, - FRR Backup path
Gateway of last resort is not set
B 172.16.162.11/32 [20/0] via 172.16.19.129 (nexthop in vrf default), 01:31:00
L 172.16.162.12/32 is directly connected, 02:48:01, Loopback400
RP/0/RSP1/CPU0:ED_MEX_1#ping vrf prueba 172.16.162.11
Tue Aug 20 13:06:43.515 UTC
Sending 5, 100-byte ICMP Echos to 172.16.162.11, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
RP/0/RSP1/CPU0:ED_MEX_1#sho bgp vpnv4 unicast
Tue Aug 20 13:07:12.093 UTC
BGP router identifier 172.16.161.1, local AS number 64512
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0x0 RD version: 4750076
BGP main routing table version 2221719
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 64512:2005 (default for vrf prueba)
*> 172.16.162.11/32 172.16.19.129 0 0 2005 i
*> 172.16.162.12/32 0.0.0.0 0 32768 ?
Peer LDP Identifier: 150.220.250.1:0
TCP connection: 172.16.19.129:646 - 172.16.19.130:53085
Graceful Restart: No
Session Holdtime: 180 sec
State: Oper; Msgs sent/rcvd: 40/221; Downstream-Unsolicited
Up time: 00:28:04
LDP Discovery Sources:
Addresses bound to this peer:
150.220.2.57 150.220.250.1 150.220.250.209 150.220.253.1
150.228.30.101 150.228.110.100 150.228.115.101 172.16.12.9
172.16.12.157 172.16.18.5 172.16.19.129 172.16.49.17
172.17.0.1 189.1.9.1 189.1.9.13 189.1.9.153
189.1.9.201 189.1.11.13
Configuration on Cisco 7600:
ip vrf prueba
rd 64512:2005
route-target export 64512:2005
route-target import 64512:2005
ip vrf forwarding prueba
ip address 172.16.162.11 255.255.255.255
interface GigabitEthernet9/10
ip address 172.16.19.129 255.255.255.252
speed nonegotiate
mpls mtu 1550
mpls ldp discovery transport-address interface
mpls bgp forwarding
mpls label protocol ldp
mpls ip
router bgp 2005
bgp router-id 150.220.250.1
bgp log-neighbor-changes
neighbor 172.16.19.130 remote-as 64512
address-family ipv4
no synchronization
neighbor 172.16.19.130 activate
maximum-paths 2
no auto-summary
exit-address-family
neighbor 172.16.19.130 send-community both
neighbor 172.16.19.130 next-hop-self
neighbor 172.16.19.130 inter-as-hybrid
exit-address-family
address-family ipv4 vrf prueba
no synchronization
network 172.16.162.11 mask 255.255.255.255
exit-address-family
PE_MEX_1#sho ip vrf prueba
Name Default RD Interfaces
prueba 64512:2005 Lo400
PE_MEX_1#sho ip route vrf prueba
Routing Table: prueba
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
172.16.0.0/32 is subnetted, 2 subnets
C 172.16.162.11 is directly connected, Loopback400
B 172.16.162.12 [20/0] via 172.16.19.130, 01:25:19
PE_MEX_1#ping vrf prueba 172.16.162.12
Sending 5, 100-byte ICMP Echos to 172.16.162.12, timeout is 2 seconds:
Someone have a idea what happen with this, or if is necesary integrate other command
Best Regards
Solved! Go to Solution.
08-20-2013 03:03 PM
Hi Saul,
One more thing. You probably want to configure the following commands on the IOS and IOS-XR side respectively, so that routes are kept on the ASBR even though the VRF might not exist locally.
IOS:
router bgp 2005
no bgp default route-target filter
IOS-XR:
router bgp 64512
retain route-target all
Also, you need to enable MPLS on the interAS link (equivalent of "mpls bgp forwarding" on the IOS side) with the following command:
router bgp 64512
mpls activate
08-21-2013 12:18 AM
Dear Saul,
you could try to ping with a source address as a starter... and do a traceroute to see what might be going on.
if you could post the config from ASBR-B and Carmen and the "show bgp vpnv4 all
is this a production? if not then you could run a "debug mpls packet" as well
Michel.
08-20-2013 02:14 PM
Hi Saul,
It looks like you want to configure interAS option b (ebgp vpnv4). You do not need to run LDP between the two ASes.
One very important thing though is to configure a static route on the XR side as follow.
router static
172.16.19.129/32 GigabitEthernet0/2/0/17
08-20-2013 03:03 PM
Hi Saul,
IOS:
router bgp 2005
IOS-XR:
router bgp 64512
router bgp 64512
mpls activate
08-20-2013 03:29 PM
Thanks soo much Harold
with the Static route
router static
the trouble is resolve but
when we try to make other vrf for Inter-AS we need a static route for each one?
best regards
08-20-2013 04:00 PM
Hi Saul,
I am glad to hear it works now. You only need to add one static route for each neighbor ASBR. So if you only add additional VRFs, there is no need to add any additionnal static route.
08-20-2013 05:28 PM
The other trouble with the traffic when we active the vrf prueba on other router en MPLS-A can ping to ASBR MPLS-A but it´s impossible to ping the ASBR-B we need to redistributed the OSPF internal to BGP
ASBR-A#ping vrf prueba 172.16.16.129
Sending 5, 100-byte ICMP Echos to 172.16.16.129, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 64/67/72 ms
ASBR-A#ping vrf prueba 172.16.162.11
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
CARMEN
carmen#sho ip route vrf prueba
o - ODR, P - periodic downloaded static route, H - NHRP
+ - replicated route, % - next hop override
172.16.0.0/32 is subnetted, 4 subnets
C 172.16.16.129 is directly connected, Loopback400
B 172.16.162.11 [200/0] via 150.220.250.1, 01:28:10
B 172.16.162.12 [200/0] via 172.16.19.130, 01:28:10
B 172.16.162.30 [200/0] via 150.220.250.1, 01:28:10
carmen#ping vrf prueba 172.16.162.12
carmen#ping vrf prueba 172.16.162.11
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/65/72 ms
the routing configuration on ASBR-A
router ospf 1
log-adjacency-changes
network 150.220.1.0 0.0.0.3 area 0
network 150.220.1.16 0.0.0.3 area 0
network 150.220.2.12 0.0.0.3 area 0
network 150.220.2.16 0.0.0.3 area 0
network 150.220.2.56 0.0.0.3 area 0
network 150.220.2.64 0.0.0.3 area 0
network 150.220.2.252 0.0.0.3 area 0
network 150.220.21.12 0.0.0.3 area 0
network 150.220.21.16 0.0.0.3 area 0
network 150.220.30.4 0.0.0.3 area 0
network 150.220.31.24 0.0.0.3 area 0
network 150.220.51.0 0.0.0.3 area 0
network 150.220.250.1 0.0.0.0 area 0
network 150.220.250.208 0.0.0.3 area 0
network 172.16.12.44 0.0.0.3 area 0
network 172.16.12.48 0.0.0.3 area 0
network 172.16.12.156 0.0.0.3 area 0
network 172.16.49.16 0.0.0.3 area 0
network 172.17.0.1 0.0.0.0 area 0
network 189.1.9.0 0.0.0.3 area 0
network 189.1.9.4 0.0.0.3 area 0
network 189.1.9.8 0.0.0.3 area 0
network 189.1.9.12 0.0.0.3 area 0
network 189.1.9.36 0.0.0.3 area 0
network 189.1.9.152 0.0.0.3 area 0
network 189.1.9.156 0.0.0.3 area 0
network 189.1.9.200 0.0.0.3 area 0
network 189.1.11.12 0.0.0.3 area 0
maximum-paths 8
default-information originate metric-type 1
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
router bgp 2005
neighbor 150.220.250.31 remote-as 2005
neighbor 150.220.250.31 update-source Loopback0
neighbor 150.220.250.202 remote-as 2005
neighbor 150.220.250.202 update-source Loopback0
neighbor 150.228.22.101 remote-as 64912
neighbor 150.228.22.101 shutdown
address-family ipv4
no synchronization
neighbor 150.220.250.31 activate
neighbor 150.220.250.202 activate
neighbor 150.228.22.101 activate
neighbor 150.228.22.101 distribute-list defa-git out
maximum-paths 2
no auto-summary
exit-address-family
neighbor 150.220.250.31 send-community both
neighbor 150.220.250.202 send-community both
exit-address-family
no synchronization
network 172.16.162.30 mask 255.255.255.255
exit-address-family
you can help me with something, we thing that´s a redistribution but we try to put into the OSPF and BGP on ASBR-A but failed
Best Regards
08-21-2013 12:18 AM
Dear Saul,
Michel.
08-21-2013 06:53 AM
Hi Saul,
The one thing I see that is not right is the following:
The next hop that Carmen sees should be ASBR-A neighbor address.
Could you please remove the following lines from ASBR-A configuration.
They are not required and could be causing issue.
08-21-2013 09:40 AM
Harold thanks
we only put next-hop-self on route reflectors and ping is successfull
the final configuration on cisco 7600 is:
router bgp 2005
address-family ipv4
no synchronization
maximum-paths 2
no auto-summary
exit-address-family
neighbor 150.220.250.31 next-hop-self
neighbor 150.220.250.202 next-hop-self
exit-address-family
thanks
Best Regards
08-21-2013 09:51 AM
Hi Saul,
The next-hop-self is usually not required for the VPNv4 address family as it is normally done automatically. It might be just a glitch that could have been triggered by the previous statements that you removed.I am glad to hesr that it works now.
