05-07-2014 04:05 AM
In IOS-Xr when i do a copy run tftp: the system sets the destination filename as you can see below to "running-config"
RP/0/0/CPU0:router_4#copy running-config tftp:
Wed May 7 12:52:37.457 UTC
Host name or IP address (control-c to abort): []?10.10.10.10
Destination file name (control-c to abort): [running-config]
In IOS the behavior is to set the destination filename to hostname-confg
cpe_1#copy running-config tftp:
Address or name of remote host []? 10.10.10.10
Destination filename [cpe_1-confg]?
Is there an easy way to get the IOS-XR box to behave in the same way as the IOS box? When i run copy run tftp: i want the destination filename to be set to hostname-confg.
/Regards Peter
05-08-2014 09:06 AM
No, but it's something we should enhance, thanks for bringing it up.
05-08-2014 11:51 PM
05-09-2014 04:16 AM
We've started the discussions on it already Peter. Will let you know where it goes.
09-01-2014 06:42 AM
Any update on this enhancement? Will it make the 5.1.3 release.
Regards Peter
09-01-2014 07:48 AM
hi peter,
the ddts is not fixed yet, unfortunately it wont make the XR513 (scheduled 9/5).
regards
xander
05-13-2014 03:11 AM
Peter,
The Development team will change the behavior to match IOS, thanks for bringing it up. DDTS used to track this is CSCuo77951. I don't have an ETA yet, but we will get this done.
Eddie.
05-13-2014 03:37 AM
And thanks for the update Eddie.
Must say that you guys are doing an excellent work here in the forum for the IOS-Xr platform. Keep up the good work.
Regards Peter
