fly
Crs-1 ABF traceroute policy routing
We config ABF on crs-1 interface to policy traffic to another next hop
But when we use traceroute. Policy not work
Cco said ABF not support ip option.  Traceroute is one of ip option
How can I verify this policy
Re: Crs-1 ABF traceroute policy routing
Hello Fly,
Normally default traceroute does not use ipv4 option and should work just fine.
We can not test ABF with traffic originating from the router where the ABF is applied to. It has to be a transit traffic and ABF has to be applied to an ingress interface of the router with ABF.
Here is the example:
RP/0/RP1/CPU0:pixies#sh run ipv4 access-list abf33
Tue May 22 09:53:52.884 CEST
10 permit ipv4 192.168.101.0 0.255.255.255 any nexthop 10.12.113.2
20 permit ipv4 any any
Traceroute from the adjacent router:
before ABF configuration
RP/0/RP1/CPU0:placebo#traceroute 77.77.77.77
Tue May 22 09:46:12.446 CEST
Tracing the route to 77.77.77.77
1 192.168.101.2 9 msec 8 msec 7 msec
2 12.1.1.1 14 msec * 11 msec
After the ABF configuration on the ingress if of pixies
Tue May 22 09:49:12.049 CEST
1 192.168.101.2 17 msec 9 msec 7 msec
2 10.12.113.2 11 msec 11 msec 7 msec  <--------------------  NH from ABF
3 13.1.1.1 7 msec * 9 msec
RP/0/RP1/CPU0:pixies#show access-lists abf33 hardware ingress location 0/2/CPU0
Tue May 22 09:50:55.047 CEST
10 permit ipv4 192.0.0.0 0.255.255.255 any (52 hw matches) (next-hop: 10.12.113.2) <------------------  matching entries in HW
20 permit ipv4 any any (25 hw matches)
/A
fly
hi Alexei
    Thank you!
    we met a weired problem, we config ABF,next-hop
    but doesn't work
    we have two crs-1 and one 7609
   two crs-1 config as below
  270 permit ipv4 58.240.152.0 0.0.0.255 any nexthop 210.52.241.229
270 permit ipv4 58.240.152.0 0.0.0.255 any nexthop 210.52.241.225
  trace from 7609
NJ-A-JPGX-SR7609-1#traceroute
Protocol [ip]:
Target IP address: 120.2.2.2
Source address: 58.240.152.81
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to 120.2.2.2
1 221.6.0.249 0 msec
   221.6.2.253 4 msec
   221.6.1.109 0 msec
2 210.52.241.229 12 msec
221.6.2.13 4 msec
   210.52.241.229 8 msec
3 * * *
4 *
   219.158.96.106 52 msec *
221.6.2.13 4 is not policy route, is default route  in routing table,   correct policy route path is 210.52.241.229
   ios-xr version is 3.8.4
   is this a bug
   thank you!
Fly
Hello Fly,
Correct me if I didn’t get it write.
On the CRS we apply the ACL with the NH 210.52.241.229 and at the trace with ttl 2 we get a reply from 221.6.2.13 instead of expected 210.52.241.229
  221.6.2.253 4 msec
  221.6.1.109 0 msec
221.6.2.13 4 msec
3 * * *
What I see is that from the 7600 we have 3 routes to the destination via 221.6.0.249, 221.6.2.253 and 221.6.1.109.
Are all these 3 IP addresses belonging to our CRSes and all 3 of them have ingress ABF ACL?
I’d suggest to simplify the routing to narrow down the issue.
  • •1.       Make sure the route from 7600 to 120.2.2.2 has only one path and that interface is connected to our CRS with the ABF ACL.
  • •2.       As was suggested by Max, put ABF ACL with the HW count in order to verify how many tracert packet hit this acl.
/A
You can put an hardware egress access-list on the egress interface used for the nexthop you configured, and make sure it is matching traffic.
Just configure your acl matching the traffic that is rerouted by the ABF and apply it on the interface with the 'hardware-count' keyword:
ipv4 access-group [name] egress hardware-count
Then use in exec:
show access-list ipv4 [name] hardware egress location 0/x/CPU0
(x is the linecard slot where the egress interface is located).
737
