04-05-2012 02:58 AM
Hi Expert,
I need to replace SPA card to resolve the error
%L2-PLIM_ASIC-4-HW_WARNING : plaspa instance 0: (plaspa port 2 jacket slot 0) RSI Spi Error was reported
The plaspa port 2 jacket slot 0 would be SPA slot 0 (0/0/0), correct?
NAME: "0/PL0/*", DESCR: "Cisco Carrier Routing System SPA Interface Processor Card"
PID: CRS1-SIP-800 , VID: V04
NAME: "0/0/0", DESCR: "2-port OC48/STM16 POS/RPR Shared Port Adapter"
PID: SPA-2XOC48POS/RPR , VID: V02
NAME: "POS0/0/0/0", DESCR: "OC48 SR/STM16 I-16"
PID: SFP-OC48-SR , VID: V01 ,
NAME: "POS0/0/0/1", DESCR: "OC48 SR/STM16 I-16"
NAME: "0/0/2", DESCR: "2-port OC48/STM16 POS/RPR Shared Port Adapter"
Thank you for all replies
Solved! Go to Solution.
04-05-2012 05:45 AM
If the power we get is too low, replacement won’t fix it either.
/A
04-05-2012 05:56 AM
Thank you. I will update the result once.
04-22-2012 09:56 PM
Hello Alexei,
The problem can be solved with you advised. Many thanks!!!
04-23-2012 05:50 AM
Can i monitor Tx/Rx power via SNMP? if yes, please let me know MIB to me? Thanks
04-23-2012 12:02 PM
That is not implemented on CRS.
/A
05-04-2012 05:40 AM
Hello Alexei
What is plaspa port ? can you please give me an idea for it ?
thanks
sudhir
05-05-2012 01:05 PM
PLA stands for PLIM LINK ASIC. PLASPA used on the SIP card for CRS and it is the interface controller for the PLIM.
In the ingress direction it takes all the traffic coming from the different ports on the PLIM and places them into virtual queues.
In the egress direction it takes all the traffic from the EgressQ ASIC buffers it and then transmits it to the appropriate egress port.
/A
