ā12-09-2011 12:27 AM
i just moved services from GSR 12404 to CRS1/8 and there is no possibility do add service-policy to L3 subinterface.
RP/0/RP0/CPU0:XXX#conf t
Fri Dec 9 09:25:55.690 CET
RP/0/RP0/CPU0:XXX(config)#interface tenGigE 0/0/0/0.900
RP/0/RP0/CPU0:XXX(config-subif)#service-policy input 300mbps
RP/0/RP0/CPU0:XXX(config-subif)#commit
Fri Dec 9 09:26:06.587 CET
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/RP0/CPU0:XXX(config-subif)#show configuration failed
Fri Dec 9 09:26:11.842 CET
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface TenGigE0/0/0/0.900
!!% 'qos_ea' detected the 'fatal' condition 'QoS is not supported on sub-interfaces'
end
Any help ?
Solved! Go to Solution.
ā12-09-2011 12:47 AM
Hello Dragoljub,
Qos on vlan interfaces is not supported for FP140/FP40 LCs.
āMQC-based QoS configuration will be accepted only on the port level but not on the VLAN subinterface level.ā
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.8.4/general/release/notes/reln_384.html
/A
Hello Dragoljub,
/A
ā12-16-2011 02:55 AM
Actualy it is possible to match VLAN on physical interface and make something like this.
service-policy input customers-qos
service-policy output customers-qos
interface TenGigE0/0/0/0.100
desc customerA
interface TenGigE0/0/0/0.101
desc customerB
class-map match-any vlan100
match vlan 100
end-class-map
class-map match-any vlan101
match vlan 101
end-class-map
policy-map customers-qos
class vlan100
police rate XXX mbps
conform-action transmit
exceed-action drop
class vlan101
exceed-action drop
This works perfect.
ā10-01-2014 08:48 AM
I am trying to configure QoS in CRS with FP140. We have the release 4.2.1.
This link has an example but we are receiving the same error.
Do you know if this support is hardware based?
Thank you
