Does a route-policy override BGP split-horizon rule in IOS-XR?
If I receive a default route from a non-client, can I turn around and send it to another non client if I have the following applied to the non-client?
prefix-set send-default
  0.0.0.0/0
end-set
route-policy DEFAULT-POLICY
  if destination in send-default then
    pass
  else
    drop
  endif
end-policy
 neighbor-group BLAH
  remote-as XXXXX
  password encrypted XXXXXXX
  description iBGP to Decryptors
  update-source Loopback0
  address-family ipv4 unicast
   route-policy DEFAULT-POLICY out
   soft-reconfiguration inbound always
 neighbor X.X.X.X
  use neighbor-group BLAH
end
1 ACCEPTED SOLUTION
Hi Carlopez,For BGP to inject
Hi Carlopez,
For BGP to inject a default rotue you need the "default-information originate" command, unfortunately, you can't redistribute or regenerate a route via the RPL method you described.
regards
xander
Xander Thuijs CCIE #6775 Principal Engineer ASR9000, CRS, NCS6000 & IOS-XR
I tested this in our lab and
I tested this in our lab and got it to work by adding "default-originate" under the address family. This would not work with out the above command entered. Which is what we expect due to the bgp rr non-client-to-non-clinet rule.
Hi Carlopez,
regards
xander
Thanks for the response,
Thanks for the response, Xander! Much appreciated.
276
