Error on CRS-1
darora_83
Hi All ,
We have a Fp140 card reloaded due to the following error.
plim_xge[242]: %PLATFORM-CIH-5-ASIC_ERROR : pla[0]: A
parity error has occurred causing  performance loss transient. 0x10440003
plim_xge[242]:
%PLATFORM-CIH-5-ASIC_ERROR_HARD_RESET_START : pla[0]: HARD_RESET needed 0x10440003
Cisco error message decoder provides following explanation.
%PLATFORM-CIH-5-ASIC_ERROR [chars][[dec]]: [chars] error has occurred[chars]%s [hex]
[chars] [chars]
Explanation    An ASIC error has occurred and been handled.
Can someone help me undertsand if issue was with FP140 card or the Associated PLIM.
Deepak
6 Replies 6
xthuijs
Deepak, looks like your card hit a parity error (hardware/memory fault).
this can either be a hard error or something transient.
If this happens again I would open a TAC case and ask for this card to be exchanged.
regards
xander
Hi Xander ,
what card needs to be replaced. PLIM or FP140 in case error appears again.
Deepak
Deepak,
Based on my previous experiences with similar issues , FP40 replacement is required.
Steve
jameel noori
Hello Deepak,
Its seems to be parity error and FP may need a replacement if its reoccurnecing else can kep under monitoring.
smilstea
Hi Deepak,
As Xander mentioned please open a TAC case.
This looks like a PLIM issue as the error is coming from the PLA, but more of the logs should be looked at by TAC to verify.
Sam
Yigal Dekalo
Deepak,
This error was reported by your PLIM ASIC (PLA0). We have 2 of them on every PLIM. This is a log level 5 - notification.
That said, its better you proceed with a TAC case as you might want this to be looked just to be safe.
If you like to track this down I would run the following commnad:
show asic-errors plim asic 0 all location 0/x/CPU0 - X stands for the slot #.
The same info can found in "dir harddisk:/ASIC-ERROR. We keep these records in case the LC had been reset by the system in case we had expereinced an event where we could not recover.
This is all valid for a single/random occurance, if you keep get this message in your syslog and the output of the above command shows a pattern or a trend please go ahead and open SR.
When you do, please capture the following:
show log
show ver br
show inst ac su
ad show platfrom
admin show diag
show asic-errors plim asic trace all location 0/x/CPU0
show controllers plim asic summary location 0/0/CPU0  <= That maps your PLA to interfaces and/or SIP/SPA HW if exists. Since this is Taiko (CRS-3 AKA 140 Fabric/Line Cards) and I see XGE, I would guess your PLIM is one of these:
14X10GBE
1X100GBE
20X10GBE
show inter br loc 0/x/cpu0
Yigal
