07-16-2013 03:21 AM
Hello All,
Is mac-move feature supported on ASR9000?
For example is it possible to enable mac-move notifications per bridge-domain?
Ante
Solved! Go to Solution.
07-16-2013 10:00 AM
Ante,
Yes, you can do it by using the mac secure feature. For example:
l2vpn
bridge group bgarland
bridge-domain bgarland
mac
secure
action none
logging
mtu 9200
neighbor 192.168.1.12 pw-id 1113
This will not take an action, but will give you a syslog showing the mac move from one port to another.
thanks,
Bryan
07-16-2013 10:00 AM
Ante,
l2vpn
mac
secure
action none
logging
mtu 9200
thanks,
Bryan
07-16-2013 11:54 PM
Thank you for your help Bryan.
