Community Member
Memory Troubles on ASR 9000
Hi actually we are operating two ASR9000 on High availability on a network of MPLS, when ask the routing table for a expecific VRF have not trouble whit obtein it but when ask the general routing table the devices send the follow information:
RP/0/RSP0/CPU0:ED_MEX_2#show bgp vrf campus neighbors 172.16.19.9 advertised-routes
Fri Sep 27 13:19:16.466 pst
% Failed to retrieve data from EDM server: 'BGP' detected the 'resource not available' condition 'Code(0)': Not enough memory
RP/0/RSP1/CPU0:ED_MEX_1#show bgp vrf campus neighbors 172.16.19.5 advertised-routes
Fri Sep 27 13:17:25.582 UTC
someone know something about of this nemonic or we need to upgrade the memory on the devices.
Best Regards
1 ACCEPTED SOLUTION
This looks like CSCuc15603.
If you are on 4.2.3 please load CSCuh52959 (BGP Umbrella DDTS #3 for 4.2.3)
HTH,
Sam
HTH,
Sam
Community Member
Hi thank you for your answer Samuel
Recommend that I use and exact version that fixed releases or use that more actually.
ASR9K-iosxr-px-5.1.0.tar
Best Regards
Community Member
Hi Samuel Other thing es referent for PIE file, we need to install PIE for MPLS for version 4.2.3, we need to install again all the PIE files for the new actuallization.
Best Regards
Not quite sure I follow follow the last two posts.
If you are wanting to get to a release where this is fixed I would recommend 4.3.4 coming out in 2-3 weeks. If you need the latest new features then go to 5.1.0 or 5.1.1 when it comes out in Jan.
Can you clarify the pie question?
Sam
Community Member
Hi Samuel
Sorry had not understood the process.
We only need to install the asr9k-p-4.2.3.CSCuh52959.tar for version 4.2.3 and that´s all, I thing that need to upgrade the totally version IOS XR with PIE files.
Thank you Samuel
Yes that SMU will fix the BGP issue you are seeing. I would also recommend installing CSCui33805 at a minimum.
Thnaks,
Sam
1247
