Highlighted
Netflow on CRS-3
We are implementing DDoS solution in our network and the netflow protocol is lunch on core routers - the CRS-3
I've got the folloing monitor-map:
flow monitor-map arbor-ddos-mpls
record mpls ipv4-fields
exporter arbor-ddos
cache timeout active 30
cache timeout inactive 15
The point is that CRS-3 is sending netflow record to DDoS system  ( arbor) with the records from MPLS VPN service.
I would like to filter force CRS-3 to not to send this MPLS VPN netflow information.
is there any chance to do it ? I was thinking about :
record mpls ipv4-fields labels 1
but is it only for labels  to be used for hashing
I would be appreciated for any help
Kind Regards
Marcin
1 REPLY
Netflow on CRS-3
Hi Marcin,
Unfortunately, if you try to sample an MPLS+IPv4 packet and only send the IPv4 part in the records, it's not possible with IOS-XR,
Best Regards,
N.
165
