10-17-2013 11:03 PM
Cisco ASR9006 IOS XR 4.3.1 doesn't show NAT statistics. For example: show cgn nat44 natXX statistics
RP/0/RSP0/CPU0:Oct 17 11:42:22.964 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65900, node
0/RSP0/CPU0). No response from 'cgn_ma' (jid 1075, node 0/RSP0/CPU0) within the timeout period
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:42:34.527 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65900, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:42:46.096 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat3/stats' from 'show_cgn_nat44_stats' (jid 65899, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:44:09.403 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/cgn1/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
(100 seconds)
(100 seconds)
(100 seconds)
(100 seconds)
Recently, everything works fine. There was no any changes.
Could anyone help me to resolve the issue?
Konstantin
Solved! Go to Solution.
10-18-2013 08:59 PM
Hi Konstantin,
Yes, you can restart cgn_ma process which normally should not have service impact. We provide that as a work-around in similar cases. You can give it a try with that and see if it fixes the issue or not.
Can you pl. send "show process blocked" output as well ? If it shows cgn_ma in the list of blocked processes, process restart is a good way of coming out of it.
If you want detailed level trouble-shooting, you can raise a service request (SR) and Cisco support team can help.
regards,
Somnath.
10-21-2013 08:20 AM
Hi Konstantin,
What was before "SYSDB-SYSDB-7-INFO" line ? Can you pl. cut and paste multiple error msgs (as part of "sh logging") ?
I'm not aware of any known issue with this msg.
If you would like to us to do detailed analysis, we would need complete log and the commands that were executed before the issue was seen. Did ISM card go through any reload during that time ?
Does it work fine after 'process restart cgn_ma' ?
regards,
Somnath.
10-21-2013 11:31 PM
Those are caused by CSCui39371 (can be ignored) in this context.
10-18-2013 02:04 AM
Hi Konstantin,
Can you please send the following output ?
- show run
- show platform summary location
- show process cgn_ma
regards,
Somnath.
10-18-2013 02:29 AM
Hi Somnath,
#show platform summary location all
Fri Oct 18 13:17:04.992
Platform Node : 0/RSP0/CPU0 (slot 0)
PID : A9K-RSP-4G
Card Type : ASR9K Fabric, Controller, 4G memory
VID/SN : V03 / FOC15078EWY
Oper State : IOS XR RUN
Last Reset : User Initiated reload
Process: reload
: Tue Aug 20 10:25:59 2013
Configuration : Power is enabled
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 1.06(20120210:003513)
IOS SW Ver : 4.3.1
Main Power : Power state Enabled. Estimate power 205 Watts of power required.
Faults : N/A
Platform Node : 0/RSP1/CPU0 (slot 1)
PID : A9K-RSP-4G
VID/SN : V02 / FOC142683EY
Process: reload
: Tue Aug 20 15:00:03 2013
Bootup enabled.
Monitoring enabled
IOS SW Ver : 4.3.1
Faults : N/A
Platform Node : 0/0/CPU0 (slot 2)
PID : A9K-8T-L
Card Type : 8-Port 10GE Low Queue Line Card, Requires XFPs
VID/SN : V03 / FOC153282Z2
Last Reset : Reloading managed node
Process: insthelper
: Fri Aug 16 11:48:31 2013
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 1.03(20100211:014208)
IOS SW Ver : 4.3.1
Main Power : Power state Enabled. Estimate power 575 Watts of power required.
Faults : N/A
Platform Node : 0/1/CPU0 (slot 3)
PID : A9K-ISM-100
Card Type : Integrated Services Module
VID/SN : V01 / FOC1706N0P0
Last Reset : MBI-HELLO reloading node on receiving reload notification
Process: mbi-hello
: Thu Aug 29 10:55:57 2013
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 1.2(20091201:235620)
IOS SW Ver : 4.3.1
Main Power : Power state Enabled. Estimate power 405 Watts of power required.
Faults : N/A
Platform Node : 0/1/CPU1 (slot 3)
Card Type : Integrated Services Module (Service Engine)
Oper State : APP-READY
Last Start Time : Tue Sep 3 14:37:10 2013
Last Ready Time : Tue Sep 3 14:39:13 2013
Uptime : 1078:37:53
BIOS Ver : 0.17 (Thurley.3.60.18.0033)
SW Ver : 1.1.1.0 (Built on May 08 2013, from services/cgn@r431-support/3)
App Status : 8 CGv6 Application instance(s) is/are running
Platform Node : 0/2/CPU0 (slot 4)
PID : A9K-ISM-100
VID/SN : V01 / FOC1704N09P
Process: mbi-hello
: Thu Aug 29 11:31:19 2013
Bootup enabled.
Monitoring enabled
IOS SW Ver : 4.3.1
Faults : N/A
Platform Node : 0/2/CPU1 (slot 4)
Last Start Time : Tue Sep 3 14:37:20 2013
Last Ready Time : Tue Sep 3 14:39:46 2013
Uptime : 1078:37:20
Platform Node : 0/3/CPU0 (slot 5)
PID : A9K-ISM-100
VID/SN : V01 / FOC1704N09Q
Process: mbi-hello
: Tue Aug 20 10:50:48 2013
Bootup enabled.
Monitoring enabled
IOS SW Ver : 4.3.1
Faults : N/A
Platform Node : 0/3/CPU1 (slot 5)
Uptime : 1078:37:54
RP/0/RSP0/CPU0:deg-nat01.#
RP/0/RSP0/CPU0:deg-nat01.# show process cgn_ma
Fri Oct 18 13:18:53.717 MSK
Job Id: 1075
PID: 602460
Executable path: /disk0/iosxr-service-4.3.1/0x100000/bin/cgn_ma
Instance #: 1
Version ID: 00.00.0000
Respawn: ON
Respawn count: 1
Max. spawns per minute: 12
Last started: Tue Sep 3 14:35:27 2013
Process state: Run
Package state: Normal
Started on config: cfg/gl/service-cgn/
Process group: central-services
core: MAINMEM
Max. core: 0
Placement: DLRSC Tracker
startup_path: /pkg/startup/cgn_ma.startup
Ready: 1.757s
Process cpu time: 81.527 user, 6.092 kernel, 87.619 total
JID TID CPU Stack pri state TimeInState HR:MM:SS:MSEC NAME
1075 1 1 52K 10 Reply 25:48:11:0377 0:01:27:0579 cgn_ma
1075 2 0 52K 10 Receive 1078:43:26:0449 0:00:00:0001 cgn_ma
1075 3 0 52K 10 Receive 1078:43:26:0427 0:00:00:0000 cgn_ma
1075 4 0 52K 10 Condvar 97:04:59:0192 0:00:00:0025 cgn_ma
1075 5 1 52K 10 Receive 1078:38:43:0702 0:00:00:0013 cgn_ma
RP/0/RSP0/CPU0:deg-nat01.# show process cgn_ma detail location all
Fri Oct 18 13:18:18.805
node: node0_0_CPU0
No such process cgn_ma
node: node0_1_CPU0
node: node0_2_CPU0
node: node0_3_CPU0
node: node0_RSP0_CPU0
Job Id: 1075
PID: 602460
Instance #: 1
Respawn: ON
Respawn count: 1
Process state: Run
core: MAINMEM
Max. core: 0
Ready: 1.757s
Running path: /disk0/iosxr-service-4.3.1/0x100000/bin/cgn_ma
Package path: /pkg/bin/cgn_ma
Job-id-link: 1075
group_jid: 8600,0,0,0
fail_count: 0
this pcb: 0xe7ffe838
next pcb: 0x6016f400
jobid on RP: 0
Standby Status: 2
1075 1 1 52K 10 Reply 25:47:38:0871 0:01:27:0579 cgn_ma
1075 2 0 52K 10 Receive 1078:42:53:0943 0:00:00:0001 cgn_ma
1075 3 0 52K 10 Receive 1078:42:53:0922 0:00:00:0000 cgn_ma
1075 4 0 52K 10 Condvar 97:04:26:0687 0:00:00:0025 cgn_ma
1075 5 1 52K 10 Receive 1078:38:11:0197 0:00:00:0013 cgn_ma
node: node0_RSP1_CPU0
Job Id: 1075
PID: 606510
Instance #: 1
Respawn: ON
Respawn count: 1
Last started: Tue Sep 3 14:36:43 2013
Process state: Run
Started on config: cfg/gl/service-cgn/cgn1/ord_a/enter
core: MAINMEM
Max. core: 0
Ready: 1.940s
Job-id-link: 1075
fail_count: 0
jobid on RP: 0
Standby Status: 2
role_event_clinfo: 5009c234
Proc role state: backup
Process cpu time: 31.437 user, 12.015 kernel, 43.452 total
1075 1 0 36K 10 Receive 0:00:00:0228 0:00:43:0449 cgn_ma
1075 2 1 36K 10 Receive 1078:41:35:0991 0:00:00:0001 cgn_ma
1075 3 1 36K 10 Receive 1078:41:35:0811 0:00:00:0000 cgn_ma
The config is too long. I absolutely confident that recently it works.
Is it possible to restart cgn_ma process? Would be any service impact?
Konstantin
10-18-2013 08:59 PM
Hi Konstantin,
regards,
Somnath.
10-21-2013 04:36 AM
Hi Somnath,
Very thanks.
The cgn_ma process was in blocked state.
I noticed that this occured after these message:
%SYSDB-SYSDB-7-INFO :
exec:oper/tty/gl/________/________/vty/3/stats/conn-out/: rc 0x40824200 ('sysdb' detected the
'warning' condition 'A SysDB client attempted to register for verification or as an EDM on a
path which was already registered')
What does it means? Could we avoid this problem in the future?
Konstantin
10-21-2013 08:20 AM
Hi Konstantin,
regards,
Somnath.
10-21-2013 10:50 PM
Hi Somnath.
I've calculated from time when process was blocked in logs were:
LC/0/2/CPU0:Oct 17 04:21:55.946 cgv6_services[140]: core_event_logging_init[835] core 2, Error code 1, Msg: ** i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 :: ** , 'cgv6_services' detected the 'warning' condition 'No CGN config'
LC/0/2/CPU0:Oct 17 04:21:55.946 MSK: cgv6_services[140]: %PLATFORM-CGV6_SERVICES-7-GENERIC_ERROR : core 2, Error code 1, Msg: ** i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 :: ** , 'cgv6_services' detected the 'warning' condition 'No CGN config' 0x49418200
R LC/0/2/CPU0:Oct 17 04:21:55.946 cgv6_services[140]: core_event_logging_init[835] core 2, Error code 1, Msg: ** i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 :: ** , 'cgv6_services' detected the 'warning' condition 'No CGN config'
There was no any change in config at this time. What does these messages mean?
Konstantin
10-21-2013 11:31 PM
10-21-2013 11:42 PM
Great!
Thanks.
And it is fixed in 4.3.2. Currently, we use 4.3.1.
10-22-2013 12:30 AM
Hi Somnath,
The problem reproduced again on another ASR and with 4.3.1.
#show processes blocked
Tue Oct 22 11:18:12.172 MSK
Jid Pid Tid Name State TimeInState Blocked-on
65551 16399 1 ksh Reply 1152:52:17:0014 16395 devc-conaux
65554 61458 2 devb-umass Reply 0:00:00:0126 53284 io-usb
98 49187 2 umass-enum Reply 1152:52:21:0728 1 kernel
98 49187 6 umass-enum Reply 1152:52:15:0896 53284 io-usb
98 49187 7 umass-enum Reply 1152:52:18:0625 1 kernel
98 49187 8 umass-enum Reply 1152:52:17:0227 1 kernel
98 49187 9 umass-enum Reply 1152:52:15:0896 1 kernel
52 65573 2 attachd Reply 1152:52:18:0576 53292 eth_server
52 65573 3 attachd Reply 1152:52:18:0574 24595 mqueue
89 65574 6 qnet Reply 0:00:00:0386 53292 eth_server
65584 65584 2 devb-umass Reply 0:00:40:0630 53284 io-usb
51 65590 2 attach_server Reply 1152:52:18:0090 24595 mqueue
65594 77882 2 devb-umass Reply 0:00:04:0484 53284 io-usb
65603 798787 1 exec Reply 672:13:27:0244 16395 devc-conaux
433 237664 1 tftp_server Reply 1152:47:58:0911 24595 mqueue
315 598246 2 lpts_fm Reply 0:00:00:0176 286865 lpts_pa
1075 610601 1 cgn_ma Reply 0:08:25:0003 454777 node 0/1/CPU0 cgn_ea
65893 616034661 1 exec Reply 0:00:00:0164 1 kernel
65894 616063334 1 more Reply 0:00:00:0075 24593 pipe
65895 609853799 1 exec Reply 0:03:35:0428 1 kernel
65897 616063337 1 show_processes Reply 0:00:00:0000 1 kernel
RP/0/RSP0/CPU0:nag-nat01.msk#
RP/0/RSP0/CPU0:nag-nat01.msk#show processes blocked 1075 extended
Tue Oct 22 11:18:44.970 MSK
1075 610601 1 cgn_ma Reply 0:08:57:0723 454777 node 0/1/CPU0 cgn_ea
Following thread 1 to process cgn_ea, pid 454777 on node 0/1/CPU0
139 454777 1 cgn_ea Receive 0:01:06:0352
139 454777 2 cgn_ea Receive 191:03:14:0571
139 454777 3 cgn_ea Receive 0:08:57:0746
Resuming display of process cgn_ma, pid 610601, jid 1075
1075 610601 2 cgn_ma Receive 1152:46:18:0789
1075 610601 3 cgn_ma Receive 1152:46:18:0674
1075 610601 4 cgn_ma Cond 191:03:12:0306 (0x50040608)
1075 610601 5 cgn_ma Receive 1151:56:49:0818
And we see only this message:
exec:oper/tty/gl/________/________/vty/1/stats/conn-out/: rc 0x40824200 ('sysdb' detected the
RP/0/RSP0/CPU0:Oct 22 11:10:50.726 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-7-INFO :
RP/0/RSP0/CPU0:Oct 22 11:10:51.084 MSK: exec[65895]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rancid' from '2a02:2168:202:1:77:37:251:71' on 'vty1'
RP/0/RSP0/CPU0:Oct 22 11:11:03.514 MSK: exec[65895]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rvp' from '2a02:2168:204:0:227:eff:fe02:7350' on 'vty1'
RP/0/RSP0/CPU0:Oct 22 11:11:27.364 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/cgn1/pcpcounters' from 'show_cgn_nat44_pcp_counters'
(jid 65894, node 0/RSP0/CPU0). No response from 'cgn_ma' (jid 1075, node 0/RSP0/CPU0) within
the timeout period (100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:11:43.377 MSK: config[65885]: %MGBL-SYS-5-CONFIG_I : Configured from
console by asaveliev on vty0 (2a02:2168:204:0:290:27ff:fe23:f4dd)
RP/0/RSP0/CPU0:Oct 22 11:12:14.581 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65894, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:12:19.944 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:12:31.496 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65901, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:13:34.229 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65893, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:14:30.973 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for
'oper/service-cgn/gl/nat44/nat1/putil/invrf/CGN1/address-rangefilter/b9131474,b91314e1/' from
'show_cgn_ma_nat44_pool_util' (jid 65893, node 0/RSP0/CPU0). No response from 'cgn_ma' (jid
1075, node 0/RSP0/CPU0) within the timeout period (100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:15:42.562 MSK: exec[65900]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rancid' from '2a02:2168:202:1:77:37:251:71' on 'vty0'
RP/0/RSP0/CPU0:Oct 22 11:15:56.076 MSK: exec[65894]: %SECURITY-login-6-AUTHEN_SUCCESS :
RP/0/RSP0/CPU0:Oct 22 11:16:08.669 MSK: exec[65882]: %SECURITY-login-6-AUTHEN_SUCCESS :
RP/0/RSP0/CPU0:Oct 22 11:17:23.634 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65905, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:36.484 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65902, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:50.271 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat3/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:50.787 MSK: exec[65893]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rvp' from '2a02:2168:204:0:227:eff:fe02:7350' on 'vty0'
Konstantin
10-22-2013 02:22 AM
Hello Somnath,
We use every 1 and 4 minutes rancid functionaliry to collect counters from #show cgn nat44 natXX stat via CLI becouse of it is impossible to get this information through SNMP.
Could it be root cause of the issue?
Konstantin
10-22-2013 05:58 AM
Hi Konstantin,
I think you are hitting the following:
CSCuh61188 cgn_ma process blked/show cmds fail on executing show cgn nat44 mapping
Do not include the following command in your script:
show cgn ... pcpCounters
Try it after that and let me know if it helps.
regards,
Somnath.
10-22-2013 06:18 AM
Hello Somnath,
Could you explain this bug, CSCuh61188.
I can't view the details.
Is there a workaround for this issue? Or we shall upgrade IOS-XR?
Thanks.
10-22-2013 06:52 AM
Hi Egor,
Looks like Release-note tag was not set properly - that could be reason why is it not visible.
Here are the details:
Symptom:
After execution of "show cgn <> pcpCounters" command cgn_ma gets reply blocked on cgn_ea. Afterwards no other "show cgn" cli responds. The mentioned CLI is not supported on ISM and not handled gracefully. Hence, the process gets blocked.
Conditions:
Execution of "show cgn <> pcpCounters"
Workaround:
"process restart cgn_ma" to unblock the cgn_ma process.
More Info:
It is present in 4.3.1 release.
regards,
Somnath.
10-22-2013 07:00 AM
Thanks a lot, Somnath!
This is exactly our issue.
But one little question: is this issue resolved in 4.3.2 or later IOS-XR?
Thanks.
