PIC Edge Unipath on A9K 4.0.1
Hello A9K Experts,
I pretend to implement a PIC Edge Unipath solution but it's no working properly on my lab scenario.
The router learns the following prefix from iBGP (MPLS VPN neighbour 10.181.1.7) and from eBGP (195.9.60.1):
* i40.40.40.40/32         10.181.1.7               0    100             0 1234 i
*>                              195.9.60.1               0                      0 1234 i
Only the best entry enters the routing table, as it should:
B    40.40.40.40/32 [20/0] via 195.9.60.1, 00:25:10
I have this configuration for the vrf
router bgp xxxxx
vrf TESTE123
  rd xxxxx:xxxxxxx
  label-allocation-mode per-vrf
  address-family ipv4 unicast
   table-policy Botnet
   additional-paths receive
   additional-paths send
   additional-paths selection route-policy TESTE123
  pass
end-policy
But cef doesn't take into account the PIC Edge configuration, since only the best path is computed there through the eBGP neighbour.
RP/0/RSP0/CPU0:A9k-03#show cef vrf TESTE123 40.40.40.40/32 detail
Mon Jan  2 12:03:53.786 WET
40.40.40.40/32, version 15, internal 0x40000001 (ptr 0x9cfdc21c) [1], 0x0 (0x0), 0x0 (0x0)
Updated Jan  2 11:37:41.672
Prefix Len 32, traffic index 0, precedence routine (0)
  gateway array (0x9ccee3c0) reference count 15, flags 0x80600, source rib (3),
                [1 type 3 flags 0x901101 (0x9cd8307c) ext 0x0 (0x0)]
  LW-LDI[type=0, refc=0, ptr=0x0, sh-ldi=0x0]
  Level 1 - Load distribution: 0
  [0] via 195.9.60.1, recursive
   via 195.9.60.1, 5 dependencies, recursive, bgp-ext [flags 0x20]
    path-idx 0
   next hop 195.9.60.1 via 195.9.60.0/30
    Load distribution: 0 (refcount 1)
    Hash  OK  Interface                 Address
    0     Y   GigabitEthernet0/1/0/4.60 remote
Should the PIC EDGE operation pre-compute the label for the iBGP Path ? Or am i seeing this the wrong way ?
PIC EDGE Multipath with eiBGP multipath works perfectly!
Thanks!
David
1 ACCEPTED SOLUTION
Re: PIC Edge Unipath on A9K 4.0.1
Hello David,
Configure the router policy like this
  set path-selection backup 1 install multipath-protect advertise
end-policy
/A
Hello David,
end-policy
/A
Thanks Akiritch !
It does work! But a few more comments:
The control-plane verification is identical with the PIC Edge Multipath (with eiBGP multipath enabled)
B    40.40.40.40/32 [20/0] via 10.181.1.7 (nexthop in vrf default), 00:01:01
                             [20/0] via 195.9.60.1, 00:01:01
But the forwarding-plane has it´s difference and it works perfectly has intended! Can i assume this is the normal operation ?
Tue Jan  3 10:27:33.188 WET
40.40.40.40/32, version 19, internal 0x40040001 (ptr 0x9cfdc7cc) [1], 0x0 (0x0), 0x4100 (0x9e511368)
Updated Jan  3 10:12:16.365
   via 10.181.1.7, 7 dependencies, recursive, backup [flags 0x110]
    path-idx 0
    next hop VRF - 'default', table - 0xe0000000
    next hop 10.181.1.7 via 16009/0/21
     next hop 10.181.64.17/32 Te0/0/0/0.2  labels imposed {16001 16001}
   via 195.9.60.1, 7 dependencies, recursive, bgp-ext [flags 0x20]
    path-idx 1
     next hop 195.9.60.2/32 Gi0/1/0/4.60 labels imposed {None}
My last questions are:
Why is this feature so poorly documented on the IOSXR command reference and configuration guide ?
How can a Customer Technical Team configure this feature without Cisco Engineers help ?
Or am i looking on the wrong documents ?
Once again thank you!
Hello David,
Try “show bgp vrf TESTE123 40.40.40.40”, one path should be marked as the best and another as the backup.
Yes, you are correct, the feature documentation is poor and we have provided this feedback to the documentation team.
/A
Thanks Akiritch. We did check the bgp table too and the only difference on it between the Multipath and Unipath option  is this:
Multipath
    10.181.1.7 (metric 200) from 10.181.1.7 (10.181.1.7)
      Received Label 16001
      Origin IGP, metric 0, localpref 100, valid, internal, multipath, backup, add-path, import-candidate, imported
     195.9.60.1 from 195.9.60.1 (195.10.10.4)
       Origin IGP, metric 0, localpref 100, valid, external, best, group-best, multipath, import-candidate
Unipath
      Origin IGP, metric 0, localpref 100, valid, internal, backup, add-path, import-candidate, imported
      Origin IGP, metric 0, localpref 100, valid, external, best, group-best, import-candidate
And the same routing table entry for both
B    40.40.40.40/32 [20/0] via 10.181.1.7 (nexthop in vrf default), 00:03:19
                             [20/0] via 195.9.60.1, 00:03:19
Interesting to note that admin distance of 20 via 10.181.1.7 when it is an iBGP neighbor. It seems necessary to achieve the intended result. And it works!
Once again thank you.
PS: I cannot stress more the fact that the IOSXR documentation is indeed very poor.
1908
