SPAN on ASR9K just doesn't work
I'm confused and none of the documents I'm reading is helping.  I'm trying to do a local SPAN session on an ASR9K.  I'm using source ports that are sub-interfaces, like te0/4/0/5.1024 (but do not have the "l2transport" option enabled).  My destination port is l2transport, I only see broadcast traffic from those links come into the sniffer, never any type of regular traffic.  I have never been able to get this to work.  My config is below, what am I not understanding here?
monitor-session MONTEST
destination interface GigabitEthernet0/3/0/18
description sniffer port
l2transport
interface TenGigE0/4/0/5.1024
description Monitored Port
vrf EX-DEM
ipv4 address 61.8.44.1 255.255.255.252
encapsulation dot1q 1024
tm
hi tm,
you probably need an acl on l3 interfaces that have a capture keyword on them.
see section L3 Spanning Example from https://supportforums.cisco.com/docs/DOC-15772
regards
xander
Xander Thuijs CCIE #6775 Principal Engineer ASR9000, CRS, NCS6000 & IOS-XR
Re: SPAN on ASR9K just doesn't work
This is my config I just tried.  Still, no packets.  I removed the bundle-ether interface that I was also looking at to get rid of the LACP messages.  So only the L2 broadcasts were coming across, I can't seem to pick up any L3 traffic and this is so frustrating becuase it would take me 2 secs to have this working on a 7600.
ipv4 access-list SPAN
10 permit ipv4 any any capture
20 permit icmp any any capture
30 permit ipv4 any any
vrf EX-DEM
  acl
ipv4 access-group SPAN ingress
ipv4 access-group SPAN egress
your config seems fine with this Tm.
can you check the np counters for the NP attached to the te 0/4/0/5 interface to make sure packets are captured by the span and acl for replication.
also what version are you using for this exercise? and what smu's do you have installed? there have been some span issues and I want to rule out those from playing up on us here.
regards
xander
214
