02-15-2014 11:03 PM
Cisco recently released Cisco XRv 5.1.1 which is IOS XR running in a VM. I thought it would be nice track features working not working and if Cisco could comment on the roadmap.
Working:
ISIS
BGP
LDP
Not working:
EoMPLS
VPLS
Control plane is up for EoMPLS and VPLS but no traffic passes through. Post anything you have tested.
Daniel Dib
CCIE #37149
Please rate helpful posts.
07-14-2015 08:46 AM
Does ABF without VRF work?
02-24-2014 01:15 PM
I guess the same for l2vpn xconnect? I set it up and it doesn't work.
02-24-2014 05:09 PM
Yes, as mentioned before, l2vpn / vpls is not supported yet.
03-24-2020 09:34 AM
Hi Vinit,
For L2VPN, is data-plane already supported on higher versions? Let's say 6.x something.
Chris
03-01-2014 05:46 AM
Multicast routing does not seem to work over MPLS P2MP TE tunnels. Although the packets show up as forwarded out the MTE interface, they are not. I ran a packet capture to confirm this.
RP/0/0/CPU0:XR1#sh mfib int tunnel-mte5
Sat Mar 1 13:43:45.131 UTC
Interface : tunnel-mte5 (Enabled)
SW Mcast pkts in : 0, SW Mcast pkts out : 100
TTL Threshold : 0
Ref Count : 5
03-01-2014 01:49 PM
Hi all,
Can you please help me.I have setup my XRv using vbox and gns3 but when i run the XRv my ping not working. My interface at both up.
03-01-2014 01:51 PM
Hi Jasper,
Did you allow all the vlans on the interface on the vm side.
Also, what kind of interfaces have you added on the vbox. is it E1000.
Vinit
03-01-2014 03:49 PM
Hi vinijain,
On the vbox under promiscuous mode i set it to allow VMs then on adapter i set it on 1000 m server.
04-24-2014 05:45 PM
Once in in a while I have disconnect and reconnect the cables in GNS3 to get pings to work. This really stumped me be the first - I watched a 10 minute video which repeated all the step I already did, and then at the end there was a quick blurb about this bug.
03-05-2014 06:03 AM
Daniel.dib can you please share your setting on XRv vm.
03-06-2014 02:46 PM
TE path protection also not supported on XRv.
RP/0/0/CPU0:XR1(config-if)#show conf failed
Thu Mar 6 22:45:07.297 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface tunnel-te0
path-protection
!!% The requested operation is not supported: Path-protection is not supported on this platform
end
04-21-2014 07:28 AM
Can't enter following commands:
1) (config)#mpls ldp router-id loopback 0
% Invalid input detected at '^' marker.
2) Command completion doesn't work for
mpls ldp
label
local
advertise
explicit-null
hierarcy.
3) Despite the fact I have loopback properly configured, I don't see LDP binding for it on remore router.
4) Locally I see
10.19.19.16/32, rev 2
Local binding: label: ImpNull
No remote bindings
despite explicit-null configured in 2)
Any advice ?
09-18-2014 03:55 AM
Hi ,
i guess this link will help explaining how to allocate implicit null.
http://wiki.kemot-net.com/mpls-ldp-local-label-allocation-filtering.
Good Luck :)
04-23-2014 01:09 PM
As far as I can tell bundle-ether interfaces do not work at least with my basic set. Can someone else confirm?
RP/0/0/CPU0:GCT#show run int bundle-ether 1
Wed Apr 23 20:06:37.109 UTC
interface Bundle-Ether1
ipv4 address 192.168.99.1 255.255.255.0
RP/0/0/CPU0:GCT(config)#show
Wed Apr 23 20:07:02.347 UTC
Building configuration...
!! IOS XR Configuration 5.1.1
interface GigabitEthernet0/0/0/5
bundle id 1 mode on
end
RP/0/0/CPU0:GCT(config)#commi
Wed Apr 23 20:07:10.927 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/0/CPU0:GCT(config)#show configuration failed
Wed Apr 23 20:08:36.461 UTC
!! found below.
bundle id 1 mode on
!!% 'CfgMgr' detected the 'fatal' condition 'This configuration has not been verified and can not be accepted by the system.'
end
04-23-2014 10:43 PM
ISIS seems does not work with sub-interface on XRV :D
