Hulc LED Process
billy.bakti
Hi All,..
I saw in my switch there is a hig processor CPU in PID 110, could you please advice me what it is? and how to solve this?
Device type : WS-C3560G-48PS
Switch#sh proc cpu sor
CPU utilization for five seconds: 23%/0%; one minute: 22%; five minutes: 21%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
110 11990607 1436516 8347 15.97% 15.83% 15.84% 0 Hulc LED Process
37 Replies 37
Yudong Wu
Level 7
Level 7
Hulc LED Process is a process responsible for link status detection.
If there is SFP port in use, it might be a little bit high.
You can check if you hit the following bug.
CSCsi78581 Hulc LED Process uses 10-15% CPU on Catalyst 3750/3560.
We have a similar problem on a 2960 with SFP ports.
Is this bug only related to 3750/3560 or also to 2960 ? I can't find a bug on the bug toolkit...
Our CPU is running around 25 - 30 % so we would like to decrease it if possible.
Do you know a workaround ?
gr
That bug is not related to 2960.
I tested 2960 in the lab. If it is 2960 with PoE, Hulc LED process will use about 15% CPU.
In general, it is normal for 2960 to have cpu usage around 15-40%.
If you don't have any performance issue, you can ignore this.
CSCsi78581 lists this fixed in in 12.2(44)SE only, when it will be fixed in other newer versions ?
I have it on 48 ports 2960 thta can ony run 12.2(50) and higher.
On one of the 2960-48 that suffer this, I've loaded for a try 12.2(52)SE
Hulc LED remained the same, but general CPU utilli went up actually with "REP LSL" ?!?.
CPU utilization for five seconds: 34%/0%; one minute: 30%; five minutes: 29%
114     9582762   1518651       6310 15.65% 15.40% 15.50%   0 Hulc LED Process
96        1834       108      16981  5.11%  0.41%  0.08%   1 SSH Process
238      192955     73776       2615  3.35%  0.63%  0.40%   0 SNMP ENGINE
236       78907    133133        592  2.07%  0.31%  0.17%   0 IP SNMP
183     4008328 164163844         24  1.27%  7.01%  7.28%   0 REP LSL Hello PP
Can't Cisco fix this ?
disable not-connected ports and you'll see a drop in the cpu usage for this process
I shut down the SPF ports not in use and saw CPU drop by a minimum of 20% on all of my 2960S-POE switches:
Then it came right back up to %60
Upgrade to either 12.2(55)SE3 or 12.2(58)SE1.
After disable two SFP ports in 2960 the "Hulc LED process" dropped to 6.23%. Before it was 15.65%!!
leolaohoo,
     This IOS (58) isn't consuming a lot of memory?
I've got news for you George, STAY AWAY from IOS level 15.0.  Across the board, it's got a memory leak issue WITHOUT any configs.
I'm currently using 12.2(58)SE1 and I have no issue.
i've got the same problem. We have two 3560x 48P running IOS 12.2(58)SE2 and the HULC LED process takes over 15% cpu load.
For what this process is responsable?
    3333333333333333333333333344444444443333344444333333333333
    7766663333344444888889999922222555557777700000999988888888
100
90
80
70
60
50                                *****
40 ******          ******************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    4444445444444444444444444444444444444444444444444444444444
    5533537321232332633343242222223322445244332224325233535342
100
90
80
70
60       *
50 **  * *         *                   *           *   * *
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
     1       1                 1     1111                       1
    7068757780566565576559785560556660000566555666976756656774670765667657
    3032391000910845988349359340222180000048268309429544494069810073970443
100  *       *           *     *     ****                       *
90  *       *           * *   *     ****         *             *
80  * *    **       *   * *   *     ****         *  *      *   *
70 ** ** ****       **  ***   *    *****  *     *****     ** ***** ***  *
60 *******************  **** **  ******* ** ********* ****** ***** **** *
50 **********************************************************************
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
3560-x#sh processes cpu sorted 5min
CPU utilization for five seconds: 35%/0%; one minute: 35%; five minutes: 38%
129  1769580351 396248960       4465 15.97% 15.39% 14.11%   0 Hulc LED Process
  60  1017745522 191907631       5303  8.62%  7.60%  7.13%   0 RedEarth Tx Mana
211  1379704348  90033624      15324  0.15%  1.23%  5.45%   0 REP LSL Hello PP
  59   266213943 266690463        998  2.23%  1.93%  1.92%   0 RedEarth I2C dri
  97   394926822  33075411      11940  1.59%  1.55%  1.54%   0 hpm counter proc
I have the same issue as ssch1ndler does; exact same code revision but my usage for this particular process sits at 20% even after turning off the 4 gi1/1 - 4 ports.
Anyone know if a newer version of the code has fixed this high cpu process?
Thank you
I have fought this matter with the TAC for quite a long time, they were adamant:
no fix is possible (hard to believe, I know) and one has to keep it as it is.
