12-04-2010 03:35 PM - edited 03-04-2019 10:41 AM
I setup a 1801 with 15.0(1)M3, also tried M4.
It has the simplest VPN client termination config ever. Yet, it fails to forward from VLAN1 to the client, unless "no ip cef" is configured. I wonder how a customer needed full performances from the box would do.
Seems like we're back 10 years, or 3, when I had found the very identical issue.
And 15.0 is supposed to be a "MD" level version
Solved! Go to Solution.
12-07-2010 05:15 AM
Hi Paolo,
I guess an unfortunate regression happened. Could you provide your configs or open a TAC case, so we can assist you properly?
thanks,
Xavier
12-17-2010 06:27 AM
You could be running into an issue with RRI installing an incorrect FIB entry on a multi-access interface for the peer. If you do a "show adj", do you see any incomplete adjacency entries off of FastEthernet0 when you try to ping? If so, the workaround is to use "reverse-route remote-peer next_hop_ip" command instead of just "reverse-route" under the crypto map.
Wen
12-17-2010 06:45 AM
Sorry I wasn't clear. The address you use in the "reverse-route" command is not the peer address, but rather the next hop ip from your WAN interface. Using your specific configuration, that would be X.X.X.Z. The bug id is CSCtg41606, and we will try to get the fix into our next 15.0(1)M5 release.
Wen
12-07-2010 05:15 AM
Hi Paolo,
thanks,
Xavier
12-07-2010 08:12 AM
Thank you for responding.
Abridged configuration below. The only thing that come to my mind, is that I have enabled LZS in transfrom-set, BTW appears to work fine.
I may try without compression later.
With CEF enabled, VPN packets going into VLAN1 are absorbed without evident trace of being processed anywhere.
no ip cef
no ipv6 cef
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp keepalive 10
crypto isakmp client configuration group aaf
key SourDough4Ever
pool default
acl 101
save-password
crypto ipsec transform-set my-set esp-aes esp-md5-hmac comp-lzs
crypto dynamic-map dynmap 10
set transform-set my-set
reverse-route
crypto map cm isakmp authorization list xx
crypto map cm client configuration address respond
crypto map cm 65535 ipsec-isakmp dynamic dynmap
interface FastEthernet0
description 01/LM--/131367/ /GCN/
ip address X.X.X.X 255.255.255.224
no ip unreachables
ip nat outside
no ip virtual-reassembly
speed auto
full-duplex
crypto map cm
interface FastEthernet1
spanning-tree portfast
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
ip address 192.168.0.3 255.255.255.0
ip nat inside
ip local pool default 192.168.5.1 192.168.5.10
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0 overload
ip route 0.0.0.0 0.0.0.0 X.X.X.Z
access-list 100 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 101 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
12-16-2010 02:28 PM
I have tried removing LZS compression, same issue.
12-17-2010 06:27 AM
Wen
12-17-2010 06:39 AM
Wen, thank you for your punctual suggestion.
Indeed I see an incomplete adjacency when CEF is enabled:
IP FastEthernet0 93.40.113.108(5) (incomplete)
However, I cannot apply the workaround you suggested, because for VPN client connections, we never know in advance what is the remote peer address.
Is there a bug ID for this issue ?
12-17-2010 06:45 AM
Wen
12-17-2010 06:56 AM
Wen,
Thank you for the clarification, the workaround is 100% effective.
Having been a Test Engineer at Cisco, I also especially appreciated your note above about regression.
Cheers, Paolo.
