Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929313members
1243618discussions
Community Activity
commit-id from the netconf device
Hi,My customer is asking if NSO can return commit-id afterissuing netconf <commit>.Here is an example the custmer pulls from the device, customer wants to know the ID (10107, for eample) after NSO uses netcont <commit>.Is there a way for NSO to retur...
sm000x by Level 1
  • 1 Views
  • 0 replies
1921 Router Config Help
Hello, I know very little about configuring cisco hardware and need some help..... we are currently running an 1800 router and I obtained a new to me 1921 router and would like to replace the 1800 router with the newer one, I managed to get it factor...
cwasilak by Level 1
  • 0 Views
  • 0 replies
Cisco SG350-28 LAG
Hi allI'm attempting to use 4 cisco SG350-28 switches connected around 100 meters apart. 3 switches will connect to 1 "central switch", each using a LAG (the far away switches are using SFP fiber modules). I have this setup and all seems to be workin...
sam7611 by Level 1
  • 72 Views
  • 2 replies
IP routing using domain
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Resolved! Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Resolved! Segment routing dynamic option
Hello Everyone, I am new to segment routing. I am trying to learn the dynamic option of segment routing traffic engineering. I have 2 directly connected routers.R1---R2R1's Gi0/0/0/1 IP address 100.10.20.1R2'2 Gi0/0/0/1 IP address 100.10.20.21.1.1.1 ...
CUCM 11.5.1 SU2 upgrade
Hello Everyone, one of my clients currently have a CUCM cluster with 1 publisher and 6 subscribers, this cluster is running version 11.5.1 SU2. i am planning a refresh upgrade to version 14 using PCD. but before this upgrade, i am planning a minor up...
Cisco ISE 3.2 OVA instable crashes
Hi  Everyone,Cisco ISE 3.2 keeps crashing several days after the installation.The installation has been done successfully without any problems.After a couple of days the installation is malfunctioning.After several installations and change of the sel...
Tom -K by Level 1
  • 44 Views
  • 1 replies
Unable to create a building in DNA 2.3.5.5-70026
Hi,we have this fresh install of DNA Center 2.3.5.5-70026. I've been able to create areas using the Intent API but I can't create a building.sitePath = "/dna/intent/api/v1/site" headers = {'content-type': 'application/json'} headers["X-Auth-Token"] =...
