Firewall Switch Module 'admin' context is full
kevinhobson2000
Hi i have been getting this message on my FWSM and was wondering how i go about resolving this.
Cheers
Kev
5 Replies 5
s-andersson
How many interfaces are allocated on the admin context?
The maximum amount of interface on one context is 256
Best regards Stefan (Sweden)
This happens when i try and add a new ACL. Yet it says it has used only 75% anyone come accross this.
Kev
Please can you post the error message.
Usually the message that you talking about is just indicating how much of the maximum ressources you have allready used. In your case you still have 25% of the maximum possible ACLs free of 75% of it used.
Do you use single or multiple context mode.
If you are in multi context mode then type the following command and post the result :
enable
changeto context system
show resource acl-partition
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_2_3/fwsm_ref/s.htm#wp2077431
Usually you have totaly limit, for the whole FWSM balde, of 150k ACLs.
Even if you split it to 12 (default) patitions then you have quit a lot of ACL.
150k / 12 = 12,5k ACLs. of each partitions and all firewalls in that partition.
Note: Remove confidential informations.
sincerely
Patrick
The Software Version is FWSM Firewall Version 2.3(1)7
FWSM Device Manager Version 4.1(2)
The Error message is ERROR: Unable to add, access-list config limit reached.
I suspect this is a book in the software version on the FWSM.
Cheers
Kev
Output from command:
FWSM# show resource acl-partition
Total number of configured partitions = 12
Partition #0
Mode : non-exclusive
List of Contexts : admin
Number of contexts : 1(RefCount:1)
Number of rules : 9569(Max:12248)
Partition #1
List of Contexts : omnipay
Number of rules : 6427(Max:12248)
Partition #2
List of Contexts : wups
Number of rules : 1523(Max:12248)
Partition #3
List of Contexts : schemes
Number of rules : 270(Max:12248)
Partition #4
List of Contexts : extranet
Number of rules : 408(Max:12248)
Partition #5
List of Contexts : wucom
Number of rules : 759(Max:12248)
Partition #6
List of Contexts : none
Number of contexts : 0(RefCount:0)
Number of rules : 0(Max:12248)
Partition #7
Partition #8
Partition #9
Partition #10
Partition #11
FWSM#
