TCL with CSM
Hi All
I try to use TCL script with CSM Netconfig.
My script start with the tclsh command, but each time I try to use a function (ex.: while) that required to lets the brace open I have the following error
ex.:
tclsh
set x 0
while {$x < 10} {+>missing close-brace
incr x
If I put this with CLI everythings goes OK. I don't have the "+>missing close-brace" error, but it's appear that the Netconfig want to have the { and the } on the same line.
Does anyone already have this issue ?
Thanks you very much for your help.
5 Replies 5
Gilles Dufour
you should not put tclsh at the beginning.
You can download sample scripts from the software download page.
Look at the file c6slb-apc.4-2-1.tcl
Gilles
Thanks for your reply
But if I remove the tclsh command, how can I enter in the embedded tcl cisco's interpreter ?
Does it exist another way to call tcl script ?
Does the way to call tcl script from CSM is different from router CLI ways ?
Thanks Gilles
The script can only be used for creating probes and nothing else.
When you define the probe type to be script, the CSM knows this is a TCL script.
No need for tclsh.
Gilles.
But, If i want to modify the router's running config based on a TCL condition, how can I do that without tclsh command ?
Thank you very much for your help Gilles
Does anyone has an idea for this ?
Thank you very much
