Total Mental block for VLANs
stephen.stack
Level 4
Level 4
Do i need a vlan configured on a switch in ordre for traffic on that vlan to traverse the switch on a trunk.
So, i have trunks between switch 1 and 2. and i have a trunk between switch 1 and 3. I have access ports in vlan 100 on both siwtch 2 and 3. Does switch 1 need to have vlan 100 enabled to allow traffic between switch 2 and 3.
Where is my mind gone???
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
VLANs are created on Layer 2 switches to control broadcasts and enforce the use of a Layer 3 device for communications. Each VLAN is created in the local switch's database for use. If a VLAN is not known to a switch, that switch cannot transfer traffic across any of its ports for that VLAN. So in order for VLAN 100 to be trunked across switch 1 it needs to be aware of VLAN 100.
HTH,
Mark
5 Replies 5
Mark Yeates
Level 7
Level 7
Stephen,
Yes, you will want to create a layer 2 VLAN for VLAN 100 for switches 2 and 3 VIA switch 1.
HTH,
Mark
Ok, this is good. I'm not going mad then. Why????
HTH,
Mark
Thanks for reply, it is clear now.
No problem. Glad I was able to clear things up for you.
Mark
