Terminology Legacy / MQC FRTS???
dara111983
In case of FRTS when we apply the shaping parameters, for the specific traffic-class and this class is called under the #map-class frame-relay _______ .
What is the terminology used for this tech, it comes under legacy FRTS/MQC-based FRTS??
Sample config:
class-map TEST
match protocol http
policy-map TEST
class TEST
class class-default
shape average 1024000
shape adaptive 512000
int se1/0
service-policy out TEST
class-map TEST
match protocol http
policy-map TEST
class TEST
class class-default
map-class frame TEST1
service-policy output TEST
int se0/1
frame-realy interface-dlci 402
class TEST1
what is the terminology used for them, since both are achieving the same?
Dara
Giuseppe Larosa
Hello Dara,
the first example is Modular QoS based.
In the second one you are using legacy FRTS just to reference to a service-policy that is again Modular QoS.
This second example could be defined an hybrid legacy FRTS/Modular QoS.
I think in the second example you would need frame-rel traffic-shaping command under se0/1 but this is a detail.
Hope to help
Giuseppe
The router says is terming the second one as GTS.
class-map match-all BGP
match protocol HTTP
policy-map SHAPE
class HTTP
class class-default
shape average 1000000
R2(config-if)#do sh run int se 2/0
Building configuration...
Current configuration : 546 bytes
interface Serial2/0
description FRSW
ip address 10.10.24.2 255.255.255.0
encapsulation frame-relay
serial restart-delay 0
no dce-terminal-timing-enable
no clns route-cache
frame-relay class FRTS
frame-relay map ip 10.10.24.4 204 broadcast
no frame-relay inverse-arp
end
R2(config-if)#frame traffic-shaping
Generic traffic shaping commands must be removed before enabling frame-relay
traffic shaping.
AS you can see the interface level frame-relay traffic-shaping isn't accepted when we configure this.
Hello Dara,
so the second example could be regarded as a GTS case.
Actually, GTS was available for non FR interfaces with commands like traffic-shape given in interface config mode.
This is interesting I had never used this variation on FR interfaces : or legacy FRTS or Modular QoS.
Best Regards
Giuseppe
