SSL Certificates issues on ACE module
nehakulsum
SSL certificate and keys are not been transfered from active to standby automaticaaly, could anyone tell me why is this happening and what needs to be done.
Neha
Hi Neha,
Yes - unless you are running the 2.2 version of ACE software - which is intended for really large configurations then there is no bulk certificate/key import process.
Whatever you did to import the certificates/keys on your active configs you'll need to do on the standby configs.
Note, by having missing files, replication will have been stopped.
Cathy
5 Replies 5
ciscocsoc
Level 4
Level 4
Hi Neha,
Certificates and keys are files and are not replicated between active and standby contexts. You need to manually import them into the standby context.
Cathy
HI Cathy,
Thanks for the info. So if my active ace gets failed then I need to import all my 100's or 1000's of SSL certificates and keys manually one by one?????
Your update on this will be highly appricatiated.
Thanks in advance.
Neha
Hi Neha,
Cathy
Hi Cathy,
Thanks for the information. I will upgrade the ACE firmware to 2.2 version. My last query on this is:
Can we upload multiple SSL/Certificates paralaly on ACE? Is there any concern on this?
Thanks for you support. Wait for your reply on this.
And make sure you upgrade the ACE to 2.2 not the ANM.
Hope this helps.
Sum
