Contact Center
Hi, we use a custom file in /opt/cisco/uccx/document/System that we can read and write from an uccx application with System.getProperty("uccx.customer.dir"). We use the in UCCX Editor the Document steps "Create FIle Document" to get a document variab...
Hi ,need some help on this error message.The error was: A built-in element encountered an exception of typecom.sun.jersey.api.client.ClientHandlerException. The root cause was: com.sun.jersey.api.client.ClientHandlerException: java.net.SocketTimeoutE...
kavle by Level 3
  • 167 Views
  • 4 replies
Hi,We have a user when they log into Finesse they receive "Error loading report", message. Do anyone know why this user is receiving this error? Screenshot attached below. Any assistance would be greatly appreciated. Thanks,
Hi All,I wonder if any of you have increased the vRAM on your UCCE Rogers/Aw-HDS beyond the prescribed by OVA numbers? I.e. if Rogger is said to have 6GB by the OVA can I make it 8?  SQL is eating memory plus there is some other management and securi...
Engnr by Level 1
  • 222 Views
  • 3 replies
I have script with toll free number(sip) the caller sometimes hear all audio prompts in menu, and sometime hear some audio prompts which not stable, but when I dial internally the trigger it is stable and I can hear all audio prompts in menu, What co...
matee by Level 1
  • 262 Views
  • 2 replies
Hi, We have some scripts that send a call redirect to a user's voicemail greeting and this works fine, using the call redirect step (destination = VM pilot, Called address reset to user's Ext.).The current set up from CUCM to Unity is SCCP, and I've ...
