MPX audio conferencing
Mar 26th, 2010
Hi all,
My customer has a 2 nodes CM cluster and a MPX (also CUPS and CUPCs...)
The point is that I'm trying to do audioconferences and the parties, located at differente sites, speak a mixture of G.711 and G.729.
For this reason, CM CFB doesn't work.
So I thought of using MPX to do the audioconferences.
To be honest, I don't know much about MPX, I just tested videoconferencing and some web collaboration, and we usually configure conferencing resources into routers to overcome this sw conference limitation, but as I saw that the MPX could do audioconferences I thought it was worth it to give it a try.
But it doesn't work. If all the parties speak G.711 it works fine, but as soon as one of the parties speak G.729 the conference drops.
As I said, my knowledge regarding MPX is very limited (and my ability to find what I was looking for in the documentation too :-), but I saw that you could specify the number of ports reserved for G.711 sessions and for G.729 sessions (and I did it so), so I thought ithe MPX could do transcoding if necessary.
Am I right? Should it work and I'm just misconfiguring the MPX?
Or do I need to configure transcoding in routers anyway?
Thanks in advance.
Best regards,
