Group-policy vs. Tunnel-group attributes
I am wondering if somebody knows if the options available under the group-policies and tunnel-gorup general attributes are going to be consolidated.
For example,
Depending on the image and normally you define the dns, wins, vpn-protocol, etc under the group-policy.
Normally you define the address-pool, authentication options, ect under the tunnel-group general attributes.
You can define the address-pool as well under the group-policy but will take precendece if you have it under the tunnel-group general attributes.
So, I guess I want to know why don't have all the parameters under either option or clearly defined which options go under which command.
I believe this is not clear or may I be missing something?
Thank you,
Federico.
0 Replies 0
