CISCO MARS Downgrade from 6.1.5 to 6.0.8
Luis Carranza
Hi guys!!
I got a question, I'm about to made an upgrade of my CISCO MARS due a problem that I got when I want to check the details of the incidents, I already open a case with the TAC and the y told me to do an upgrade so right now I'm making my plan and I need to know if it's possible to do a downgrade of the version, just in case that it would be necesary. I already try to find something related with this on google but I didn't find anything so I'm asking you guys.
I hope you can answer me that.
Jennifer Halim
no, unfortunately there is no way to downgrade MARS appliance. The only way is to re-image it to an earlier version.
I would suggest that you back it up before upgrading.
Thanks for the answer Jennifer, do you have the procedure for the re-image and how to made a backup.?
