The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
HelloWe currently peer with our ISP using BGP, In our BGP statement we are using route-map the route-map calls an acl which contains our subnets this is working fine, If I want to AS prepend one of our subnets would I need to remove it from the acl...
I have C9606 Switch. configure the VTP version 2 VTP domain Configure with password. and i want to see the password, and run the command Show vtp pasword but password is not showing. so how to see the c9606R Which password configure
Hi team, We have a hybrid on-prem/Azure environment but currently running ISE on-prem as a small deployment (2 nodes) as well as two load balancers. We are thinking about moving one of the ISE nodes to Azure and would like your advise on what approac...
Hi,I am using CiscoSecure ACS v4.2 appliance, in there any way that RADIUS logs upload to FTP server because it has limitation to store RADIUS logs.Please advice.Thanks,AS
HiI have just installed a new FTD and is now managed by our FMC I have noticed that in the device summary tab under chasis itas a url with the device name and our domain, any idea why please and how I can remove.?? The other FTDs we have have N/A un...
Meet Silesio Carvalho our Newest Community VIP Class of 2025 Commitment and dedication allowed Silesio to become a VIP member this year, but his story and deliveries go far beyond just technical content. Learn more about his professional history and ...
Hey guys, Im doing some maintenance on my router through putty. Basically, as the title says i gotta verify router redundancy, and i did the show redundancy states command, and it says that the peer state for it is " 1 - DISABLED" while it need it t...
In packet tracer, I enabled the following command on a switchport connected to a PC.interface f0/1 spanning-tree portfast spanning-tree bpduguard enableI removed the PC and connected a new switch on that same port (f0/1). And as expected the new ...
Greetings, Im trying to use xCommand SoftwareUpgrade operation for NH-C90 and for some reason this is what it results with: { "message" : "Timed out waiting for command result", "errors" : [ { "description" : "Timed out waiting for command ...
Studying for the CCNA exam. Currently learning about PVST+ and Rapid-PVST+.I am trying to create a lab scenario for 9 PCs spread out evenly across 3 access switches. To assign IPs to the PCs, I am thinking of using a DHCP server.QUESTIONBased on best...
I made the mistake of running "factory-reset all secure 3-pass", not realizing this would sanitize the C1121X-8P requiring me to obtain my own IOS 17.6.3a image to recover it.What do I need to do to obtain this image, or the latest official C1121X-8P...
Hi community , I hope you are doing great.After spending a good time reading and doing some troubleshooting I have decided to ask for some same.I setup guestshell in order to run python using eem. I am getting the following error : router-lab#more b...
Cisco IP Phone CP-8861 WebUI admin passwordUnable to log in writes incorrect password even after resetting all settings or factory reset, I tried both admin admin and user userIncorrect user name and/or password. Please try again.
IntroductionAccess models Bundles vs Phyiscal interfaces Linecard based subscribers Hardware requirementsRadius Source Ports PPPoE vs DHCP/IP-sessions First Sign of Life comparison between PPPoE and IPoE sessions Access Interfaces Using ambigious ...
Do I face any incompatibility issue while using anchor wlc in 8.2.170 and foreign wlc in 8.5.182 IOS? Below is the details of framework.Anchor:Hardware -Cisco WLC 2500 seriesImage- 8.2.170Foreign:Hardware- Cisco WLC 8500 seriesImage-8.5.182
