03-09-2006 09:10 PM
I need setup SSL termination on my CSS11506. I am trying to migration the CA from oracle/apache/solaris9 and find they do not use private/public key, but wallet.
How can I do with wallet? is possible to migrate wallet to CSS11506? if so, how to do it and is there any URL ?
any comments will be appreciated
Thanks in advance
Solved! Go to Solution.
03-16-2006 04:04 AM
check your ewallet.out file and verify that there is a private key inside.
try 'openssl rsa -in ewallet.out -text' and see if there is a certificate and a key present.
Gilles.
03-13-2006 02:04 AM
a wallet contains certificate and key.
You should be able to extract this info from the wallet using the wallet manager.
http://matrix.csustan.edu/docs/oracle/oas/core.1012/b13995/wallets.htm#CIHDIGED
See the export function :
Gilles.
03-15-2006 07:32 PM
Hi, Gilles,
Great thanks for your help,
I have just got news from our oracle people.
I have also tried to use "openssl pkcs12 -in ewallet.p12 -out ewallet.out"
and I have got two extracted file from different way for extract.
However, the serv cert is ok to import into CSS 11506, and successfully associated to a cert.
the private key can not be associated, it complain as:
%%File does not contain an RSA key
please advice am I did wrong for it?
Many Regards
03-16-2006 04:04 AM
Gilles.
03-16-2006 03:41 PM
yes, it fix my problem, and the private key seems working fine in my CSS11506
Thousands thanks.
