8941 not registering on CCM 7.1.5
Derek McCormick
I have 2 * 8941 phones failing to register on  CCM 7.1.5. I have downloaded the latest phone load 9-2-2 and also the device enabler software. When I go to add a phone to the Call Manager, I see the 8941 in the listed phones and I try to add it manually, it fails to register. There are plenty of DLUs left also. Am I missing something a step?
Derek
5 Replies 5
Karthik Sivaram
Level 4
Level 4
hi Derek,
Did you do a cluster wide reboot after you installed the device enabler? If not can you do that.
Karthik
I have exactly the same issue on exactly the same version cucm!
Please see
https://supportforums.cisco.com/message/3521783#3521783
Derek, did you resolve the issue? If so how did you do it?
Karthik - a cluster wide reboot, never done one although with our systems a reboot is the last thing we would want to do
Cheers
Dwayne
As previously suggested did you reboot the Publisher?  I had the exact same issue with 8945s and they registered after rebooting the Pub.
HTH,
Chris
restarting the call manager service on the publisher and subscriber resolved the issue. no need to reboot the servers
Thanks, restarting the call manager service did the job!!!!
