12-12-2011 01:39 PM - edited 03-16-2019 08:30 AM
OK, not sure why this isn't working. I have a CME 8.1 system with a B-ACD setup to do basic call queueing.
According to the documentation, you're supposed to be able to setup an "out' for the caller to press a key and get out of the queue prior to the time expiring.
I have this:
param queue-exit-option1 9
param queue-exit-extension1 4004
as part of my config; when I dial into the queue and press "9", nothing happens.
And I cannot find anything else in the Configuration Guide that even addresses this feature.
Can anyone shed some light here?
Thanks in advance.
Kevin
Full B-ACD config:
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
param number-of-hunt-grps 1
paramspace english index 1
param drop-through-option 1
param handoff-string aa
param dial-by-extension-option 1
paramspace english language en
param max-time-vm-retry 2
param max-extension-length 4
param aa-pilot 4100
param queue-overflow-extension 4004
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param send-account true
param call-retry-timer 15
param max-time-call-retry 300
param voice-mail 6000
param service-name queue
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 15
param aa-hunt1 4200
param queue-manager-debugs 1
Solved! Go to Solution.
12-12-2011 02:22 PM
It maybe that the feature is not supported on v.2.1.2.2
Check this out:
https://supportforums.cisco.com/thread/2055435
-AA
12-12-2011 02:22 PM
Check this out:
-AA
12-12-2011 02:58 PM
Interesting. Although the Configuration Guide uses v2.1.2.2 in all its examples.
I'll look into upgrading and test again.
Thanks for the tip!
12-12-2011 03:24 PM
Yep, upgrading to 3.0.0.2 did the trick!
Thanks so much!
12-13-2011 09:55 AM
I am happy to help.
-AA
04-10-2012 05:34 AM
Could you help me please /
I have been strugling on CME B-ACD, here is my Configuration please?
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 300000
no logging console
no logging monitor
enable secret 5 $1$H8Hk$f04hyqqZnWL0h/od8vlis.
aaa new-model
aaa group server tacacs+ Cisco_ACS
server 172.29.10.41
aaa authentication fail-message ^CAuthentication failed. Try again.^C
aaa authentication login default group Cisco_ACS local
aaa authentication enable default group Cisco_ACS enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group Cisco_ACS local
aaa authorization commands 1 default group Cisco_ACS local
aaa authorization commands 15 default group Cisco_ACS local
aaa accounting exec default start-stop group Cisco_ACS
aaa accounting commands 15 default start-stop group Cisco_ACS
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
network-clock-participate wic 0
no ipv6 cef
ip dhcp excluded-address 10.1.173.1 10.1.173.99
ip dhcp excluded-address 10.1.173.201 10.1.173.254
ip dhcp excluded-address 10.1.172.1 10.1.172.99
ip dhcp excluded-address 10.1.172.201 10.1.172.254
ip dhcp pool Voice
network 10.1.173.0 255.255.255.0
domain-name jas1.ds.jas.com
dns-server 172.29.10.72 172.29.10.73
default-router 10.1.173.1
option 150 ip 10.1.173.1
lease 3
ip dhcp pool Data
network 10.172.1. 0 255.255.255.0
domain-name tester.com
default-router 10.172.1.1
lease 2
no ip domain lookup
ip domain name tester.com
ip name-server 172.29.10.72
ip name-server 172.29.10.73
ip dhcp-server 10.172.1.1
ip dhcp-server 10.173.1.1
ip cef
isdn switch-type primary-ni
isdn logging
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 10.173.1.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
modem passthrough nse codec g711ulaw
sip
registrar server
voice class custom-cptone jointone
dualtone conference
frequency 900 900
cadence 100 50 100 50
voice class custom-cptone leavetone
dualtone conference
frequency 1200 1200
cadence 150 50 150 50
voice iec syslog
voice hunt-group 10 parallel
final 1003
list 1002,1003,1004,1005,1006,1007,1008,1009,1010,1011,1017,1018,1019,1020,1021,1022,1023,1024,1025
timeout 12
pilot 5000
voice translation-rule 1
rule 1 /.*/ /2167062162/
voice translation-rule 2
rule 1 /^4057062661$/ /1000/
rule 2 /^4057062663$/ /1001/
rule 3 /^4057062664$/ /1002/
rule 4 /^4057062665$/ /1003/
rule 5 /^4057062666$/ /1004/
rule 6 /^4057062667$/ /1005/
rule 26 /^4057062662$/ /5000/
voice translation-rule 3
rule 1 // // type any international plan any isdn
voice translation-profile INCOMING
translate called 2
voice translation-profile INTL
translate calling 1
translate called 3
voice translation-profile OUTGOING
translate calling 1
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
param number-of-hunt-grps 3
param aa-pilot 4057062662
param voice-mail 1234
param max-time-call-retry 700
service queue flash:app-b-acd-aa-3.0.0.2.tcl
param queue-len 15
param aa-hunt3 5003
param aa-hunt1 5001
param aa-hunt2 5002
license udi pid CISCO2921/K9 sn FTX1552AMSC
license accept end user agreement
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
archive
log config
logging enable
notify syslog contenttype plaintext
file privilege 0
username TAVAVA password 7 1xxx
username SAAABABA password 7 1XX
username PAAASS password 7 4XXX
username
username
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Connection to ASA5505 ETH Port 1
ip address 10.172.1.2 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description Connection to POE Switch Port 47
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.172
encapsulation dot1Q 172
ip address 10.172.1.1 255.255.255.0
interface GigabitEthernet0/1.173
encapsulation dot1Q 173
ip address 10.173.1.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
interface SM1/0
description Internal switch interface connected to Service Module
ip address 10.174.1.1 255.255.255.252
service-module ip address 10.174.1.9 255.255.255.252
!Application: CUE Running on SM
service-module ip default-gateway 10.174.1.10
interface SM1/1
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 10.174.1.1
ip tacacs source-interface GigabitEthernet0/0
tftp-server flash:/SCCP6945.9-2-1-0.bin1.sgn alias SCCP6945.9-2-1-0.bin1.sgn
tftp-server flash:/SCCP6945.9-2-1-0.bin2.sgn alias SCCP6945.9-2-1-0.bin2.sgn
tftp-server flash:/SCCP6945.9-2-1-0.bin3.sgn alias SCCP6945.9-2-1-0.bin3.sgn
tftp-server flash:/SCCP6945.9-2-1-0.bin4.sgn alias SCCP6945.9-2-1-0.bin4.sgn
tftp-server flash:/term75.default.loads alias term75.default.loads
tftp-server flash:/Ringtones/RingList.xml alias RingList.xml
tftp-server flash:/Ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/Ringtones/Pop.raw alias Pop.raw
tftp-server flash:/Ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/Ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/Ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/Ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/Ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/Ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/Ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/Ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/Ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/Ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/Ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server system
control-plane
voice-port 0/0/0:23
voice-port 0/1/0
description FAXMachine-01
caller-id enable
voice-port 0/1/1
description FAXMachine-02
caller-id enable
voice-port 0/1/2
voice-port 0/1/3
mgcp fax t38 ecm
mgcp profile default
sccp local GigabitEthernet0/1.173
sccp ccm 10.1.173.1 identifier 100 version 7.0
sccp
sccp ccm group 123
bind interface GigabitEthernet0/1.173
sccp ccm group 1
associate ccm 100 priority 1
associate profile 1 register confdsp1
dspfarm profile 1 conference
codec g711ulaw
maximum conference-participants 32
maximum sessions 3
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
shutdown
dial-peer voice 1 pots
translation-profile incoming INCOMING
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 10 pots
description local
translation-profile outgoing OUTGOING
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
dial-peer voice 11 pots
description long distance
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
prefix 1
dial-peer voice 12 pots
description local service
destination-pattern 9[489]11
port 0/0/0:23
dial-peer voice 13 pots
description international
translation-profile outgoing INTL
destination-pattern 9011T
port 0/0/0:23
dial-peer voice 14 pots
description local operator
destination-pattern 900
port 0/0/0:23
prefix 0
dial-peer voice 15 pots
description 911 Call
preference 5
destination-pattern 911
port 0/0/0:23
prefix 911
dial-peer voice 1000 voip
description Voice Mail Pilot
translation-profile outgoing RedirectVM
destination-pattern 1234
session protocol sipv2
session target ipv4:10.174.1.9
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 84 pots
destination-pattern 4057062662
port 0/1/0
dial-peer voice 85 pots
destination-pattern 1212
port 0/1/1
port 0/1/0
port 0/1/1
dial-peer voice 4401 voip
service aa
session target ipv4:10.173.1.2
incoming called-number 4057062662
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 4402 voip
service aa
destination-pattern 2167062162
session target ipv4:10.172.1.2
incoming called-number 2167062162
codec g711ulaw
no vad
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 778 mute-off 779
sdspfarm units 3
sdspfarm tag 1 confdsp1
conference hardware
authentication credential admin cisco
authentication credential cisco cisco
max-ephones 100
max-dn 200
ip source-address 10.172.1.2 port 2000
service phone webAccess 0
timeouts interdigit 5
system message CME B_ACD Test
url services http://10.172.1.9/voiceview/common/login.do
url authentication http://10.172.1.10/CCMCIP/authenticate.asp
cnf-file location flash:
load 7916-24 B016-1-0-4.SBN
load 7975 SCCP75.9-2-1S.loads
load 6945 SCCP6945.9-2-1-0.loads
time-zone 12
voicemail 1234
max-conferences 8 gain -6
call-forward pattern 9T
call-forward pattern ....
moh "music-on-hold.au"
web admin system
web admin customer name
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9T
transfer-pattern ....
secondary-dialtone 9
create cnf-files version-stamp 7960 Mar 19 2012 19:55:57
ephone-template 5
conference admin
softkeys idle Redial Newcall Cfwdall Dnd Pickup Mobility Login
softkeys seized Redial Cfwdall Meetme
softkeys connected Hold Trnsfer TrnsfVM Park Confrn ConfList Mobility
keep-conference
ephone-dn 1 dual-line
number 1000
label - 1000
description (405) 706-2661
name
mobility
call-forward busy 1234
call-forward noan 1234 timeout 24
ephone-dn 2 dual-line
number 1002
label - 1002
description (405) 706-2663
name
ephone-dn 3 dual-line
number 1003
label - 1003
description (405) 706-2664
name
ephone-dn 4 dual-line
number 1004
label - 1004
description (405) 706-2665
name
ephone-dn 5 dual-line
number 1005
label 1005
description (405) 706-2666
name
ephone-dn 6 dual-line
number 1006
label - 1006
description (405) 706-2667
name
ephone-dn 7 dual-line
number 1007
label - 1007
description (405) 706-2668
name
ephone-dn 8 dual-line
number 1008
label - 1008
description (405) 706-2669
ephone-dn 9 dual-line
number 1009
label - 1009
description (405) 706-2670
mobility
ephone-dn 10 dual-line
number 1010
label- 1010
description (405) 706-2671
name
ephone-dn 11 dual-line
number 1011
label - 1011
description (405) 706-2672
name
ephone-dn 12 dual-line
number 1012
label Reception- 1012
description (405) 706-2673
name Reception Desk
ephone-dn 13 dual-line
number 1013
label Guest Office 1 - 1013
description (405) 706-2674
name Guest Office 1
ephone-dn 14 dual-line
number 1014
label Guest Office 2 - 1014
description (405) 706-2675
name Guest Office 2
ephone-dn 15 dual-line
number 1015
label Conf. Rm. - 1015
description (406) 706-2676
name Conf. Rm.
ephone-dn 16 dual-line
number 1016
label - 1016
description (406) 706-2677
name
ephone-dn 17 dual-line
number 1017
label - 1017
description (406) 706-2678
name
ephone-dn 18 dual-line
number 1018
label Spare 6945 - 1018
description (406) 706-****
name Spare 6945
ephone-dn 19 dual-line
number 1019
label Spare 6945 - 1019
name Spare 6945
ephone-dn 20 dual-line
number 1020
label Spare 6945 - 1020
name Spare 6945
ephone-dn 21 dual-line
number 1021
label Spare 6945 - 1021
name Spare 6945
ephone-dn 22 dual-line
number 1022
label Spare 6945 - 1022
name Spare 6945
ephone-dn 23 dual-line
number 1023
label Spare 6945 - 1023
name Spare 6945
ephone-dn 24 dual-line
number 1024
label Reception 6955 - 1024
name Reception 6955
call-forward all 1004
ephone-dn 25 dual-line
number 1025
label Conf. Room 65 - 105
name Conference Room 6945
ephone-dn 50
number 1050
park-slot timeout 180 limit 20 recall
name Call Park
ephone-dn 51
number 1051
name Call Park
ephone-dn 52
number 1052
name Call Park
ephone-dn 53
number 1053
name Call Park
ephone-dn 54
number 1054
name Call Park
ephone-dn 55
number 8000....
mwi on
ephone-dn 56
number 8001....
mwi off
ephone-dn 99 dual-line
number 1001
label XXX - 1001
description (406) 706-2188
name Shawn Chipner
call-forward noan 1234 timeout 10
ephone-dn 1111
number 1111
label Paging - 1111
description page ALL
name Paging - 1111
paging
ephone-dn 101 octo-line
number 1478
conference meetme
ephone-dn 102 octo-line
number 1478
conference meetme
ephone-dn 103 octo-line
number 1478
conference meetme
ephone-dn 104 octo-line
number 1478
conference meetme
ephone-dn 133 dual-line
number A100
name Ad-Hoc ence
conference ad-hoc
ephone-dn 134 dual-line
number A100
name Ad-Hoc Conference
conference ad-hoc
ephone-dn 135 dual-line
number A100
conference ad-hoc
ephone-dn 136 dual-line
number A100
conference ad-hoc
ephone-dn 137 dual-line
number A101
conference ad-hoc
ephone-dn 138 dual-line
number A101
conference ad-hoc
ephone-dn 139 dual-line
number A101
conference ad-hoc
ephone-dn 140 dual-line
number A101
conference ad-hoc
ephone 1
device-security-mode none
description -Theo
mac-address 24B6.5744.EE7B
ephone-template 5
max-calls-per-button 2
paging-dn 100
type 7975
button 1:1
ephone 2
description -Pola
mac-address E8B7.48ED.D076
ephone-template 5
paging-dn 100
type 6945
button 1:2
ephone 3
description - MAR
mac-address E8B7.48ED.D070
ephone-template 5
paging-dn 100
type 6945
button 1:3
ephone 4
description - Er
mac-address E8B7.48AD.D0DF
ephone-template 5
paging-dn 100
type 6945
button 1:4
ephone 5
type 6945
button 1:5
ephone 6
type 6945
button 1:6
ephone 7
type 6945
button 1:7
ephone 8
paging-dn 100
type 6945
button 1:8
ephone 9
mac-address E8B7.48ED.D0E8
ephone-template 5
paging-dn 100
type 6945
button 1:9
ephone 10
mac-address E8B7.48ED.D0C9
ephone-template 5
paging-dn 100
type 6945
button 1:10
ephone 11
mac-address E8B7.48ED.D0BA
ephone-template 5
paging-dn 100
type 6945
button 1:11
ephone 12
description Reception Desk
mac-address E8B7.48ED.D0DA
ephone-template 5
paging-dn 100
type 6945
button 1:12
ephone 13
description Guest Office 1
mac-address E8B7.4838.4A2A
ephone-template 5
paging-dn 100
type 6945
button 1:13
ephone 14
description Guest Office 2
mac-address E8B7.48ED.D0BF
ephone-template 5
paging-dn 100
type 6945
button 1:14
ephone 15
description Conf. Rm.
mac-address E8B7.48ED.D081
ephone-template 5
paging-dn 100
type 6945
button 1:15
ephone 16
mac-address E8B7.48ED.D0F3
ephone-template 5
paging-dn 100
type 6945
button 1:16
ephone 17
mac-address E8B7.48ED.D0CE
ephone-template 5
paging-dn 100
type 6945
button 1:17
ephone 18
description Spare 6945
mac-address E8B7.48ED.D0D1
ephone-template 5
paging-dn 100
type 6945
button 1:18
ephone 19
mac-address E8B7.48ED.D0BD
ephone-template 5
paging-dn 100
type 6945
button 1:19
ephone 20
mac-address E8B7.48ED.D071
ephone-template 5
paging-dn 100
type 6945
button 1:20
ephone 21
mac-address E8B7.48ED.D0D7
ephone-template 5
paging-dn 100
type 6945
button 1:21
ephone 22
mac-address E8B7.4838.4B8B
ephone-template 5
paging-dn 100
type 6945
button 1:22
ephone 23
mac-address E8B7.48ED.F0DD
ephone-template 5
paging-dn 100
type 6945
button 1:23
ephone 24
button 1:24
ephone 99
type 7975
button 1:99
ephone-hunt 1 sequential
pilot 5001 secondary 4057062662
list 1003, 1004
timeout 2, 2
ephone-hunt 2 sequential
pilot 5002 secondary 4057062662
list 1005, 1007
timeout 3, 3
ephone-hunt 3 sequential
pilot 5003 secondary 4057062662
list 1002, 1006, 1008, 1009, 1010, 1011, 1012
timeout 6, 6, 6, 6, 6, 6, 6
Dak
Message was edited by: Davy Ad
