BARS in ccm version 7.1
lkinchen
my backup history says the last good backup was on 12-01. when I try to do a manual back up, I receive a message that a backup is currently in progress. I try to cancel it but it doesn't allow me to. it's been processing for about a week now, how can I get it to stop?
restart the DRS services, BTW there is no BARS in linux versions. it's DRF
java
if this helps, please rate
java
webstd.design
Try to reset CCM service on Publisher (forexample) or reboot your servers from console.
java
java
Yesterday, i had the same issue, then i restarted de DRF Master and local, then the problem was solved.
Does anybody know if it can be a Bug in CCM 7.1 ?
