Building Callmanager cluster
AJAZ NAWAZ
Level 5
Level 5
I understand that when deploying a CCM cluster the Publisher must built first.
Does it also have to be attached to the network before commencing with Subsciber build?. Cannnot seem to find the document at the momment expaining the prerequisites and procedures?
tia
Rob Huffman
Hi Ajaz,
Yes, this is the recommended method so the Pub/Sub relationship db replication can take place properly.
Hope this helps!
Rob
mohamedtag
Hello Anawaz ,
Yes , Everytime you Install one of the Subscribers , The Subscriber should be able to contact the PUBLISHER.
M.Tag
