Call from PSTN
MarcoM
Hi all,
when receive a call from PSTN to the extension 30 (for example) call redirect always to extension 20 and I can not call directly to internal numbers.
can anyone help me please?
In attach most important parts of the configuration.
Thanks in advance.
Debug "debug isdn q931":
May 27 17:19:16.557: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x002E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
        Calling Party Number i = 0x00A3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '331234530'
                Plan:ISDN, Type:National
May 27 17:19:16.557: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x802E callID = 0x048E switch = primary-net5 interface = User
May 27 17:19:16.565: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x802E
May 27 17:19:16.565: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x802E
        Progress Ind i = 0x8188 - In-band info or appropriate now available
May 27 17:19:26.513: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x002E
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8088 - In-band info or appropriate now available
May 27 17:19:26.513: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x802E
May 27 17:19:26.569: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x002E
So your system does not have any problem then. Its working. The problem is with your home phone. This forum cant help you with this. The analogic phone is not cisco phone. You need to contact the vendor for the phone...
Pls rate all useful posts
Please rate all useful posts
20 Replies 20
Chris Deren
Looks like it is matching "num-exp 3312345 20", it is not a good idea to use num-exp for this type of setup.
Is this CUCM or CME? If CME please use dialplan pattern to match DIDs, if CUCM use Translation patterns on CUCM or set sigDigits to 2 in your example the GW configuration in CUCM.
HTH,
Chris
Hi Chris,
thanks for reply.
I use CME, if I delete "num-exp 3312345 20" and try to make a call on 30 it was busy.
I tried to delete also all num-exp without success.
I do not understand why the call from outside sees only 3312345
P. S. should also create a dial-peer for the incoming call PSTN?
Thanks.
M
No, just add the following under telephony-service:
dialplan-pattern 1 3312345.. extension-length 2 extension-pattern ..
HTH, please rate all useful posts!
Chris
Hi Chris,
deleted num-exp and added "dialplan-pattern 1 3312345.. extension-length 2 extension-pattern .." on telephony-service, but number is always trunked on 3312345 and not forward on inside extensione (35, 30, etc.)
What may cause this issue?
Thanks.
Can you send a
'debug voip ccapi inout'
here..
Hi aokanlawon,
this is output:
CME#
May 28 17:24:25.679: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2511403, Called Number=3317545, Voice-Interface=0x315E2928,
   Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=101
May 28 17:24:25.679: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=2511403, Called Number=3317545, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
May 28 17:24:25.679: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=3317545, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=3317545
   Result=Success(0) after DP_MATCH_DEST
May 28 17:24:25.679: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=30
May 28 17:24:25.683: //-1/CE9F5BD884EE/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=2511403
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3317545
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May 28 17:24:25.683: //-1/CE9F5BD884EE/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x315E2928, Call Info(
   Calling Number=2511403,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3317545(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=101, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
May 28 17:24:25.683: //-1/CE9F5BD884EE/CCAPI/ccCheckClipClir:
   In: Calling Number=2511403(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=2511403(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 28 17:24:25.683: :cc_get_feature_vsa malloc success
May 28 17:24:25.683:  cc_get_feature_vsa count is 1
May 28 17:24:25.683: :FEATURE_VSA attributes are: feature_name:0,feature_time:735043544,feature_id:10358
May 28 17:24:25.683: //9839/CE9F5BD884EE/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2511403(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3317545(TON=National, NPI=ISDN))
May 28 17:24:25.683: //9839/CE9F5BD884EE/CCAPI/cc_process_call_setup_ind:
   Event=0x311049F0
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=3317545, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 3317545
May 28 17:24:25.683: //9839/CE9F5BD884EE/CCAPI/ccCallSetContext:
   Context=0x2BD24BD8
   >>>>CCAPI handed cid 9839 with tag 101 to app "_ManagedAppProcess_Default"
May 28 17:24:25.683: //9839/CE9F5BD884EE/CCAPI/ccCallSetupAck:
   Call Id=9839
May 28 17:24:25.683: //9839/CE9F5BD884EE/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
May 28 17:24:25.683: //-1/CE9F5BD884EE/DPM/dpMatchPeersCore:
May 28 17:24:25.683: //-1/CE9F5BD884EE/DPM/dpMatchSafModulePlugin:
May 28 17:24:25.683: //-1/CE9F5BD884EE/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
   Calling Number=3317545, Called Number=3317545, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
May 28 17:24:25.683: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3317545, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=30
May 28 17:24:25.687: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 28 17:24:25.687: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 28 17:24:25.687: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 28 17:24:25.687: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
May 28 17:24:25.687: //-1/CE9F5BD884EE/DPM/dpMatchPeersCore:
May 28 17:24:25.687: //-1/CE9F5BD884EE/DPM/dpMatchSafModulePlugin:
   dialstring=3317545, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
May 28 17:24:25.687: //-1/CE9F5BD884EE/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
May 28 17:24:25.687: //9839/CE9F5BD884EE/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=30, Params=0x2BD16C08, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
May 28 17:24:25.687: //9839/CE9F5BD884EE/CCAPI/ccCheckClipClir:
   Destination Pattern=3., Called Number=3317545, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=CE9F5BD8-A820-11E1-84EE-E8B7482D58D8, Outgoing Dial-peer=30
May 28 17:24:25.687: //9839/CE9F5BD884EE/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2511403
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3317545
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 28 17:24:25.687: //9839/CE9F5BD884EE/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x31387A3C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=2511403,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3317545(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=30, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 28 17:24:25.687: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 28 17:24:25.687: :cc_get_feature_vsa malloc success
May 28 17:24:25.687:  cc_get_feature_vsa count is 2
May 28 17:24:25.687: :FEATURE_VSA attributes are: feature_name:0,feature_time:735045112,feature_id:10359
May 28 17:24:25.687: //9840/CE9F5BD884EE/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
May 28 17:24:25.687: //9840/CE9F5BD884EE/CCAPI/ccCallSetContext:
   Context=0x2BD16BB8
May 28 17:24:25.687: //9839/CE9F5BD884EE/CCAPI/ccSaveDialpeerTag:
May 28 17:24:25.691: //-1/CE9F5BD884EE/DPM/dpAssociateIncomingPeerCore:
   Timeout=FALSE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20
May 28 17:24:25.691: //-1/CE9F5BD884EE/DPM/dpMatchSafModulePlugin:
May 28 17:24:25.691: //-1/CE9F5BD884EE/CCAPI/cc_api_create_cc_entry_common:
   Interface=0x31387A3C, Call Id=9841,
   Call Info=2511403(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   FinalDestinationFlag=TRUE, Incoming Dial-peer=20
May 28 17:24:25.691: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 28 17:24:25.691: :cc_get_feature_vsa malloc success
May 28 17:24:25.691:  cc_get_feature_vsa count is 3
May 28 17:24:25.691: :FEATURE_VSA attributes are: feature_name:0,feature_time:735042200,feature_id:10360
May 28 17:24:25.691: //9840/CE9F5BD884EE/CCAPI/cc_api_call_disconnected:
   Cause Value=65, Interface=0x31387A3C, Call Id=9840
   Call Entry(Responsed=TRUE, Cause Value=65, Retry Count=0)
May 28 17:24:25.695: //9839/CE9F5BD884EE/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May 28 17:24:25.695: //9840/CE9F5BD884EE/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=9840
May 28 17:24:25.695: //9840/CE9F5BD884EE/CCAPI/ccCallDisconnect:
   Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=65)
   Cause Value=65, Call Entry(Responsed=TRUE, Cause Value=65)
May 28 17:24:25.695: //9840/CE9F5BD884EE/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
May 28 17:24:25.695: //9841/CE9F5BD884EE/CCAPI/cc_api_delete_cc_entry:
   Interface=0x31387A3C, Disposition=0x0, Tag=0x0, Call Id=9841
May 28 17:24:25.695: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 28 17:24:25.695: :cc_free_feature_vsa freeing 2BCFDA90
May 28 17:24:25.695:  vsacount in free is 2
May 28 17:24:25.695: //9840/CE9F5BD884EE/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31387A3C, Tag=0x0, Call Id=9840,
   Call Entry(Disconnect Cause=65, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
May 28 17:24:25.695: :cc_free_feature_vsa freeing 2BCFE5F0
May 28 17:24:25.695:  vsacount in free is 1
May 28 17:24:25.695: //9839/CE9F5BD884EE/CCAPI/ccCallDisconnect:
   Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 28 17:24:25.695: //9839/CE9F5BD884EE/CCAPI/cc_api_get_transfer_info:
May 28 17:24:25.823: //9839/CE9F5BD884EE/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x315E2928, Tag=0x0, Call Id=9839,
May 28 17:24:25.823: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 28 17:24:25.823: :cc_free_feature_vsa freeing 2BCFDFD0
May 28 17:24:25.823:  vsacount in free is 0
CME#
CME#
From your logs,
I can see that the called number is 3317545. So the number is not modified in any way.
We also get a disconnect cause of 65.
Can you send a sh run of your router so we can see why the call is been disconnected..
I have looked at your config above and I can see the ff:
num-exp 331234501.. ..
num-exp 331234501... ...
num-exp 3312345.. ..
num-exp 3312345 20
The called number does not have any number expansion defined for it.
What should this number match to on your internal extenion?
Why do you have dial-peers for internal numbers in CCME? When the dialled number ia macthed it will route directly..is this the ip address of your ccme router:172.16.18.254
in attach my config.
p.s. could be a problem of the provider?
Thanks.
Can you remove this dial-peer and test again..
dial-peer voice 30 voip
destination-pattern 3.
session target ipv4:172.16.18.254
dtmf-relay h245-alphanumeric
codec g711ulaw
Pls send a debug voip ccapi inout. This time put it in a text file and attach it here
When place a call form PSTN i can type only digits 03317545 then start call automatically without giving me time to type internal number.
I did not write the config I've taken as an inheritance
Than dial-peers for internal numbers is unnecessary?
Thanks.
I do the test by calling any extension? or 3.?
Test by dialling the same number 03317545
you cant dial internal number externally
aokanlawon numer 03317545 is only root...my internal are: 35, 30....etc.
Than cannot call externally number 0331754535 ? (for example)
