Can't Dial in IP Telephony
jroderick007
I installed and configured IP Telephony. When I entered the phone number with and without dialing a 9 first, and press the Dial Button, it doesn't then. After a few seconds, it just exited. I checked my configurations and everything looks good.
Not sure where else to check.
jamison
paolo bevilacqua
Since you have no previous experience, your configurations may be likely wrong.
So you should have these reviewed before assuming you have to look for something else.
Thank you for your reply. Yes, I am new at this. We are VoIP with Cisco IP Phone 7960. I have purchased a version of 7.0.3.3 of IP Communicator (SoftPhone) that I installed on my pc and using the number pad of my keyboard to dial my cell phone for testing,  to test for our offsite workers. I have prepared and configured my Cisco Call Manager and gotten my softphone to able to grab ldap configration, from the look of it the softphone able to open without error. When I enter a phone number with a 9, and without, and then press the Dial button or press the Enter key on my keyboard, it doesn't dial.
Below is from my Call Manager.
Product Type:
Cisco IP Communicator
Device Protocol:
SCCP
Device Information
Registration
Registered with Cisco Unified Communications Manager VMS-CUCMBE
IPv4 Address
10.0.0.210
Active Load ID
Unknown
Device is Active
Device is trusted
Device Name
Description
Device Pool
View Details
Common Device Configuration
View Details
Phone Button Template
Softkey Template
Common Phone Profile
Calling Search Space
AAR Calling Search Space
Media Resource Group List
User Hold MOH Audio Source
Network Hold MOH Audio Source
Location
AAR Group
User Locale
Network Locale
Built In Bridge
Privacy
Device Mobility Mode
View Current Device Mobility Settings
Owner User ID
Phone Suite
Services Provisioning
Primary Phone
Phone Load Name
Single Button Barge
Join Across Lines
Use Trusted Relay Point
BLF Audible Alert Setting (Phone Idle)
BLF Audible Alert Setting (Phone Busy)
Always Use Prime Line
Always Use Prime Line for Voice Message
Calling Party Transformation CSS
Geolocation
Use Device Pool Calling Party Transformation CSS
Retry Video Call as Audio
Ignore Presentation Indicators (internal calls only)
Allow Control of Device from CTI
Logged Into Hunt Group
Remote Device
Protocol Specific Information
Packet Capture Mode
Packet Capture Duration
Presence Group
Device Security Profile
SUBSCRIBE Calling Search Space
Unattended Port
Require DTMF Reception
RFC2833 Disabled
Certification Authority Proxy Function (CAPF) Information
Certificate Operation
Authentication Mode
Authentication String
Key Size (Bits)
Operation Completes By
(YYYY:MM:DD:HH)
Certificate Operation Status:
None
Note: Security Profile Contains Addition CAPF Settings.
External Data Locations Information (Leave blank to use default)
Information
Directory
Messages
Services
Authentication Server
Proxy Server
Idle
Idle Timer (seconds)
Extension Information
Enable Extension Mobility
Log Out Profile
Log in Time
< None >
Log out Time
< None >
MLPP Information
MLPP Domain
MLPP Indication
MLPP Preemption
Do Not Disturb
Do Not Disturb
DND Option
DND Incoming Call Alert
Product Specific Configuration Layout
https://vms-cucmbe:8443/ccmadmin/gendeviceEdit.do?key=6e52d3aa-1042-39b6-147d-085ce4f65d29
Disable Speakerphone
Auto Line Select
IP Address Autodetection URL
LDAP Server Information File
RTP Port Range Start
RTP Port Range End
Settings Access
Verify Software Versions
Video Capabilities
Web Access
RTCP
"more" Soft Key Timer
Auto Call Select
Advertise G.722 Codec
Product Type:
Device Protocol:
SCCP
Device Information
Registration
IPv4 Address
10.0.0.210
Active Load ID
Unknown
Device is Active
Device is trusted
Device Name
Description
Device Pool
View Details
View Details
Softkey Template
Location
AAR Group
User Locale
Network Locale
Built In Bridge
Privacy
Owner User ID
Phone Suite
Primary Phone
Phone Load Name
Single Button Barge
Join Across Lines
Geolocation
Remote Device
Packet Capture Mode
Presence Group
Unattended Port
RFC2833 Disabled
Authentication Mode
Key Size (Bits)
(YYYY:MM:DD:HH)
None
Information
Directory
Messages
Services
Proxy Server
Idle
Log Out Profile
Log in Time
< None >
Log out Time
< None >
MLPP Information
MLPP Domain
MLPP Indication
MLPP Preemption
Do Not Disturb
Do Not Disturb
DND Option
Auto Line Select
RTP Port Range End
Settings Access
Video Capabilities
Web Access
RTCP
Auto Call Select
attached is the screen shot of my softphone.
Thank you in advance for your  expertise and tuteledge
OK...  You installed 'IP Telephony'...  Are we talking about Cisco CUCM?  Version 4.x, 5.x, 6.x, 7.x?  Asterix?  3Com? Avaya?  Nortel?  Skype?  Vonage?
And you entered a phone number...  On your computer?  With a softphone?  Through Outlook dialer?  On a physical IP phone?  On an analog phone?  On a cell phone?  On a tin can with a string?
And you checked your configurations...  On your router?  Your voice gateway?  Your phone?  Your computer?  Your VCR?  Your digital wristwatch?
We have no idea what you are running or how so there is no way to know what is wrong.
