CFNA/CFB
sohaildxbfze
hi,
i have a strange problem, ccm v4.1.3(sr5b), i deleted all tracks on one DID. but still the old CFNA/CFB settings are working for that DID in ccm.
Is this DID records are not still deleted from ccm, i checked route plan report, but that did not listed there.
Any clues!!!!
already did, "CUCM trace"
java
if this helps, please rate
java
16 Replies 16
Jaime Valencia
did you checked the unassigned DNs???
java
java
sohaildxbfze
yes infact i selected "All Patterns"!!!!!.i also checked on subscriber db same thing is there coz i was suspecting replication mismatch, which i verified using dblhelper & found healthy
then the actual answer is NO
all patterns DO NOT INCLUDE UNASSIGNED DNS
java
java
sohaildxbfze
i have 1 dn : 1004, i search it in both ways.
1. Selected 'All patterns' , result: it was listed
2. Selected 'Unassigned patterns', result:it was listed
What do you think which setting should i check further, because i deleted & then recreated the same DID in my extension mobility profile several times but wasnt able to get rid of VM setting on CFNA/CFB.
Same old settings are in effect, regardless of deleting & recreating the same DID entry.
Hope you will find some solution for it!!!
Have u tried restarting IPVMS and DBL services?
ok, did you deleted both entries???
because to me it sounds you left the unassigned DN which might have a partition with higher preference in the calling device css and it's still using it
delete all unassigned DNs that could match that number and then try again
java
java
sohaildxbfze
yeah i deleted both entries, then tried & stragely foiund that still i can hit DID from outside & inside that again goes to VM, how is it possible to be.
I can check also SQL, but i need to know whihc tables are use d to hold this DN information.!!!!!!
numplan table, field = DNorPattern
if nothing shows up most probably it's still on cache memory, a dbl restart might help, or a ccm restart
java
java
sohaildxbfze
i will restart sercices mentioned after production hours. Tell me which table keeps Call forwarding values.
Can i get SQL data structure from cisco.i mean database table info
same table, field names are pretty self-explanatory just look for it
no, DB definition docs were made only for linux appliance
java
java
sohaildxbfze
very soon we r upgrading ccm 413 to ccm 6.1 then to 7, can i have link for that linux doc for SQL info
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
java
sohaildxbfze
i restarted the ipvms,dbl service in the cluster but still situation is same.!!!
then look at a CUCM trace or restart the server
java
java
