Cisco IOS and North American Numbering Plan
Dear all,
My IOS is 12.4(13r)T5, RELEASE SOFTWARE (fc1)
I notice that IOS automatically change my calling and called number type when it detect my calling and called number match with North American Numbering Plan. I don't want it. Can anyone notice it before? Is this a feature of IOS?
Are there anyway to overcome this? I want type and plan to be Unknown without using voice translation rule. I mean to overcome the North American Numbering Plan detection feature of IOS.
.Jun 18 17:25:51.919 CDT: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x2 is 0x2 0x1, Calling num 3123959300
.Jun 18 17:25:51.919 CDT: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x008C callID = 0x800D switch = primary-4ess interface = User
.Jun 18 17:25:51.919 CDT: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x008C
       Bearer Capability i = 0x8090A2
               Standard = CCITT
               Transfer Capability = Speech
               Transfer Mode = Circuit
               Transfer Rate = 64 kbit/s
       Channel ID i = 0xA98397
               Exclusive, Channel 23
       Calling Party Number i = 0x2180, '5123959399'
               Plan:ISDN, Type:National
       Called Party Number i = 0x91, '8481689485'
               Plan:ISDN, Type:International
Thank you,
Aaron Harrison
I believe you can override it with isdn map under the serial interface: http://www.cisco.com/en/US/docs/ios/12_3t/dial/command/reference/dia_i2gt.html#wp1212108
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftdilnme.html
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
