CME 4.1 and call forward problem - NO TALK PATH
wreed
Hi guys. I have a CME 4.1 system with a SIP trunk for outside lines to my ISP/telephony provider. Everything works great except call forwards. The system forwards the call but neither end can talk or hear one another.
I need help with this ASAP, thanks!
10 Replies 10
paolo bevilacqua
For the traces you sent previously, can you check the media endpoints? Probably they want media to go back to you, in which case you can try configuring a voice class with media flow-through.
Hey thanks for the reply. I saw your post like this in another thread but I was confused on excatly what I need to do.
when you have a second could you explain in detail what i need to do and give me the commands to accomplish it?
Try creating a voice class with the media command, and apply on all relevant voip DPs.
Well this is weird. I do not have the media command available under a dial-peer, voice class, or global voice config. I only have "media statistics"
I am running IOS 12.4-15T3
Any other ideas?
Thanks for your continued help.
That might be because you do not have ip-to-ip gw image. In fact, for what you're doing, I suspect such image is required.
Keep in mind the SIP trunk I am connecting to is a Broadsoft VOIP server, not Cisco. I dont know if it matters.
That images is not available for the 1760.
Here are my options:
Platform: 1760
Release: 12.4.15T5 ( ED - Early Deployment )
Narrow your choices by choosing a major release.
12.4 12.3 12.2 12.1
Library
Select options from the table below to find the software you want:
Choose Options
Select Software Feature Set
ENTERPRISE BASE
ENTERPRISE SERVICES
IP/ADSL
IP/ADSL PLUS
IP/ADSL/IPX/AT/IBM/FW/IDS PLUS IPSEC 3DES
ENTERPRISE SERVICES W/O CRYPTO
ADVANCED IP SERVICES
ADVANCED SECURITY
IP VOICE
IP/ADSL/FW/IDS PLUS IPSEC 3DES
IP BASE
IP BASE W/O CRYPTO
SP SERVICES
ADVANCED ENTERPRISE SERVICES
ENTERPRISE BASE W/O CRYPTO
IP/ADSL/VOX PLUS
IP VOICE W/O CRYPTO
Understand.
Unfortunately I think that something is wrong with the media endpoints when a call is forwarded sip-to-sip, and I'm not sure what you can do about that.
wreed
I just reviewed the CME docs and I am running the correct image to support CME. It looks like the IPtoIP gateway was stopped with IOS 12.3
wreed
OK I have signed up for the Broadvoice bring your own device progam to test call forwarding. Guess what same problem.
I am thinking this has to be something on the CME side now.
Any other ideas?
