CME - Conference does not works
dsobrinho
Level 9
Level 9
Hi everybody,
I have configured a CME for a small office, and during the tests the conference did not work. I have re-check the configuration and cannot find the problem. I have attached the configuration of CME here.
Does anybody knows if can be a bug of IOS for this router 2801 or a mistake in the configuration ?
GW uptime is 2 minutes
System restarted at 19:04:37 GMT-2 Mon Jan 11 2016
System image file is "flash:c2801-advipservicesk9-mz.151-4.M10.bin"
Last reload type: Normal Reload
The IP Phones are Cisco 7942 SCCP
Best regards,
Daniel
Daniel Sobrinho
6 Replies 6
Chris Deren
Daniel,
Your config indeed looks correct, are the profiles registered with your CME? Can you post "show dspfarm all"?
Hi Chris,
All 2 profiles (XCODEC and CONFER) are registered, however, I will return this Friday to the customer and  I can collect more information.
I have check "show voice dsp error" and there is no error.
Cisco 2801 (revision 7.0) with 221184K/40960K bytes of memory.
Processor board ID XXXXXXXX
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
2 DSPs, 24 Voice resources           (16 PVDM Slot 0 and 8 PVDM Slot 1)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
125440K bytes of ATA CompactFlash (Read/Write)
Best regards,
Daniel
Daniel Sobrinho
My question was not about phone registration, but DSPFarm registration. Since you are using hardware conferencing the defined profiles register with CUCM/CME via SCCP.
Following the show dspfarm profile output:
Dspfarm Profile Configuration
 Profile ID = 1, Service = TRANSCODING, Resource ID = 1
 Profile Description : *** TRANSCODE***
 Profile Service Mode : Non Secure
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : SCCP   Status : ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 3
 Number of Resource Available : 3
 Codec Configuration: num_of_codecs:4
 Codec : g729r8, Maximum Packetization Period : 60
 Codec : g729br8, Maximum Packetization Period : 60
 Codec : g711ulaw, Maximum Packetization Period : 30
 Codec : g711alaw, Maximum Packetization Period : 30
 Profile ID = 2, Service = CONFERENCING, Resource ID = 2
 Profile Description : ***CONFERENCE***
 Number of Resource Configured : 1
 Number of Resource Available : 1
 Maximum conference participants : 8
 Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Daniel Sobrinho
Hi Chris
Problem resolved!  My mistake. I forgot the configuration below for the reason the conference does not work.
ephone-dn  3  octo-line
 number A100
 conference ad-hoc
Best regards,
Daniel
Daniel Sobrinho
dudus20122
I have similar issue. i can't connect more than 3 phones for conference call. other connections drops. See config attached.
