CME Dial Peer Stripping First Digit
cigalahgroup
          I have 2 site SITE A with CUCM 9.2 with the extension numbers 9XXX and I wan to call from SITE B which has CME . To do this I created Inter cluster trunk on the CUCM9.0 and created dial peer on CME  to receive the call and works perfectly.
The CME site users uses digit 9 to take external line to call on mobile or land lines.
When I make a dial peer with destination pattern 9... it works but they are not able to take external line since 9 is already used.  I want a dial peer like this listed below
destination pattern 29xxx where it should strip first digit 2 and send 9xxx.
Manish Prasad
Level 5
Level 5
voice translation-rule 1
 rule 1 /^2\(9...$\)/ /\1/
voice translation-profile Strip2
 translate called 1
dial-peer voice xxx voip
 translation-profile outgoing Strip2
Manish
7 Replies 7
Manish Prasad
Level 5
Level 5
 translate called 1
Manish
Thanks Manish will it work like this
voice translation-rule 9000
 translate called 9000
dial-peer voice 9001 voip
destination-pattern 2[9]...
session target ipv4:10.202.0.3
dtmf-relay h245-alphanumeric
 no vad
yes, it will work.
Suresh
Thanks Manish it worked
Rakesh K
Hi Mansih,
I was just thinking will this work or not, Could please let me know.
dial-peer voice 123 voip
destination pattern 29XXX
digit forward 4
session target ipv4 x.x.x.x
Thanks in advance
I haven't tried forward digit on VOIP dial-peer because translation profile is more powerful tool to manage digits.
If it something new to new IOS then it will works same as on POTS dial-peer and Yes it will forward only last four digits.
Manish
Hi Manish,
Thanks for adding some light.
