CME TCL script for outbound call
alex goshtaei
Hi All,
is there any TCL script available to make outbound call by CME? for example user from outside call specific number in CME, then CME asks a password or pin, after user enter the password, he would be able to make a outbound call through CME. In this case, our employee can make a outbound call to international, and our company is getting charged not employee.
thanks
Alex
7 Replies 7
Michael Owuor
Alex,
The script is attached. Keep in mind that it is not supported by TAC.
Copy the files onto flash.
Enter the following commands in configuration mode, to load and activate the script:
application
service acctfixedpin flash:acctfixedpin.tcl
param pin-len 5
param uid-len
dial-peer voice x voip
Create usernames for authentication. The usernames represent the pin that the caller dials to be authenticated. Create multiple usernames as needed:
username 12345 password 0 123456
username 54321 password 0 123456
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
On the dial-peer routing the international calls, add the command 'service fac'
Hope this helps.
Michael.
thank you very much Micheal, let me try your solution to our CME. is it working on UC500 as well?
thanks for reply,
is it working for outside caller as well or only from IP phone? for example we have employee outside our corporation, they need to call international number. is that possible for them to dial specific number to reach to CME, then dial their password, and make international call?
thanks
Hi michael ,
i tried the FAC , but there is no prompts, the call is going directly without authentication
attached is my config
thanks
edwin
Hi ,
Thanks for uploading script and procedure.
I have uploaded TCL script into router, it is asking me to give pin after that nothing happens...if i am trying to make outside calls , it doesnt happens.
dial-peer voice 3 voip
description **incoming - Remote Dial-in  **
destination-pattern .T
session target ipv4:10.228.131.5
incoming called-number .T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
AAUSMELVG01#    debug voip application digitcollect
voip application digit collect debugging is on
AAUSMELVG01#
Aug 24 23:29:01.187: //41//Digi:/C_DigitCollect_Start: Leg=41, Dialplan=True, Diaplanterm=False, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=True, Abortkey=, Terminationkey=#, Numpatterns=0, Maxdigits=0, Mindigits=0, Interruptprompt=False, InterTimeout=-1000, Initialtimeout=-1000, Mask=0 Hotword=0
Aug 24 23:29:01.187: //-1//Digi:/AFW_DigitCollect_New:
Aug 24 23:29:01.187: //-1//Digi:HN003E6688:/AFW_DigitCollect_New: DialPlan=TRUE AbortKey= TermKey=# NumPatts=0
              Enable=FALSE Consume=FALSE InterruptPrompt=FALSE minDigits=0 maxDigits=0 DialPlanTerm=FALSE hotword=0
Aug 24 23:29:01.187: //41/51CB00AF8032/Digi:/DigitCollectStart_UpdateStats:
Aug 24 23:29:01.187: //41//Digi:/DigitCollect_MLPPTuning:
Aug 24 23:29:01.187: //41//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
Aug 24 23:29:01.187: //41//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:01.187: //41//Digi:/act_DCRunning_RDone: id=41 Enable succeeded.enable=0 matchDialplan=1 numPatterns=0matchDialplanTerm=0
Aug 24 23:29:02.111: //41//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:02.111: //41//Digi:/act_DCRunning_Digit: : pLeg 41 Digit 3 Tone Mode 0
Aug 24 23:29:02.111: //41//Digi:/DigitCollect_TreatDigit:
Aug 24 23:29:02.111: //41//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=3
Aug 24 23:29:02.111: //41//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
Aug 24 23:29:02.111: //41//Digi:/DigitCollect_DialPlanMatch: Match single infotype
Aug 24 23:29:02.311: //41//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:02.311: //41//Digi:/act_DCRunning_Digit: : pLeg 41 Digit 9 Tone Mode 0
Aug 24 23:29:02.311: //41//Digi:/DigitCollect_TreatDigit:
Aug 24 23:29:02.311: //41//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=39
Aug 24 23:29:02.311: //41//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
Aug 24 23:29:02.311: //41//Digi:/DigitCollect_DialPlanMatch: Match single infotype
Aug 24 23:29:02.511: //41//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:02.511: //41//Digi:/act_DCRunning_Digit: : pLeg 41 Digit 0 Tone Mode 0
Aug 24 23:29:02.511: //41//Digi:/DigitCollect_TreatDigit:
Aug 24 23:29:02.511: //41//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=390
Aug 24 23:29:02.511: //41//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
Aug 24 23:29:02.511: //41//Digi:/DigitCollect_DialPlanMatch: Match single infotype
Aug 24 23:29:02.711: //41//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:02.711: //41//Digi:/act_DCRunning_Digit: : pLeg 41 Digit 2 Tone Mode 0
Aug 24 23:29:02.711: //41//Digi:/DigitCollect_TreatDigit:
Aug 24 23:29:02.711: //41//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=3902
Aug 24 23:29:02.711: //41//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
Aug 24 23:29:02.711: //41//Digi:/DigitCollect_DialPlanMatch: Match single infotype
Aug 24 23:29:02.711: //41//Digi:/act_DCRunning_RDone: id=41 Reporting disabled.
Aug 24 23:29:02.711: //-1//Digi:/DigitCollect_Complete: DC_MATCHED_DIALPLAN. Digits=3902
Aug 24 23:29:02.711: //41//Digi:/AFW_M_DigitCollect_EventPreProcess:
Aug 24 23:29:02.711: //41//Digi:/DigitCollectEnd_UpdateStats:
Aug 24 23:29:02.715: //43//Digi:/tcl_LegDigitCollectObjCmd: collectdigits leg_incoming param
Aug 24 23:29:02.715: //43//Digi:/C_DigitCollect_Start: Leg=43, Dialplan=False, Diaplanterm=False, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=False, Abortkey=*, Terminationkey=#, Numpatterns=0, Maxdigits=20, Mindigits=0, Interruptprompt=True, InterTimeout=-1000, Initialtimeout=10000, Mask=0 Hotword=0
Aug 24 23:29:02.715: //-1//Digi:/AFW_DigitCollect_New:
Aug 24 23:29:02.715: //-1//Digi:HN003E6C80:/AFW_DigitCollect_New: DialPlan=FALSE AbortKey=* TermKey=# NumPatts=0
              Enable=FALSE Consume=FALSE InterruptPrompt=TRUE minDigits=0 maxDigits=20 DialPlanTerm=FALSE hotword=0
Aug 24 23:29:02.715: //43/51CB00AF8032/Digi:/DigitCollectStart_UpdateStats:
Aug 24 23:29:02.715: //43//Digi:/DigitCollect_MLPPTuning:
Aug 24 23:29:02.715: //43//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
Aug 24 23:29:02.715: //43//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:02.715: //43//Digi:/act_DCRunning_RDone: id=43 Enable succeeded.enable=0 matchDialplan=0 numPatterns=0matchDialplanTerm=0
Aug 24 23:29:12.715: //43//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:15.723: //43//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:15.723: //43//Digi:/act_DCRunning_Digit: : pLeg 43 Digit T Tone Mode -1
Aug 24 23:29:15.723: //43//Digi:/act_DCRunning_RDone: id=43 Reporting disabled.
Aug 24 23:29:15.723: //-1//Digi:/DigitCollect_Complete: DC_TIMEOUT. Digits=
Aug 24 23:29:15.723: //43//Digi:/AFW_M_DigitCollect_EventPreProcess:
Aug 24 23:29:15.723: //43//Digi:/DigitCollectEnd_UpdateStats:
Aug 24 23:29:15.723: //43//Digi:/tcl_LegDigitCollectObjCmd: collectdigits leg_incoming param
Aug 24 23:29:15.723: //43//Digi:/C_DigitCollect_Start: Leg=43, Dialplan=False, Diaplanterm=False, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=False, Abortkey=*, Terminationkey=#, Numpatterns=0, Maxdigits=20, Mindigits=0, Interruptprompt=True, InterTimeout=-1000, Initialtimeout=10000, Mask=0 Hotword=0
Aug 24 23:29:15.723: //-1//Digi:/AFW_DigitCollect_New:
Aug 24 23:29:15.723: //-1//Digi:HN003E9F50:/AFW_DigitCollect_New: DialPlan=FALSE AbortKey=* TermKey=# NumPatts=0
Aug 24 23:29:15.723: //43/51CB00AF8032/Digi:/DigitCollectStart_UpdateStats:
Aug 24 23:29:15.723: //43//Digi:/DigitCollect_MLPPTuning:
Aug 24 23:29:15.723: //43//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
Aug 24 23:29:15.723: //43//Digi:/act_DCRunning_RDone: id=43 Enable succeeded.enable=0 matchDialplan=0 numPatterns=0matchDialplanTerm=0
Aug 24 23:29:17.331: //43//Digi:/AFW_M_DigitCollect_Action:
Aug 24 23:29:17.331: //43//Digi:/act_DCRunning_Disconnected:
Aug 24 23:29:17.331: //-1//Digi:/DigitCollect_Complete: DC_DISCONNECTED. Digits=
Aug 24 23:29:17.331: //43//Digi:/AFW_M_DigitCollect_EventPreProcess:
Aug 24 23:29:17.331: //43//Digi:/DigitCollectEnd_UpdateStats:
DIGIT COLLECT NOT HAPPENING...it keeps on saying ENTER YOUR PIN
